Ignition key lock - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-30-2004, 04:55 PM Thread Starter
esm
Ignition key lock
On my 96 Bronco there's every now and then only a click when I turn the ignition key. Wiggling on the keylock usually helps and the engine starts. So I replaced the keylock but no dice. Same problem. Now my wife tells me that wiggling with the shift lever helps. What do I have to replace now?
Thanks,
Ed
esm is offline
post #2 of (permalink) Old 10-01-2004, 02:31 AM
Re: Ignition key lock
Check the adjustment on the ignition switch its on top of the collum down twords the bottom. try moving it up (twords the wheel) just a bit If that doesn't work most likely its the cam inside the collum bad(expecialy if it is tilt they are real bad about this) search for my post on this. I fixed mine and posted a step by step walkthrough on this.
Jacob_Royer is offline
post #3 of (permalink) Old 10-01-2004, 11:11 AM Thread Starter
esm
I did a couple of searches but nothoing came up. Do you remember when you posted it?
esm is offline
post #4 of (permalink) Old 10-02-2004, 05:06 AM
Here is a link to the thread.
http://bbs.off-road.com/ubbthreads/s...ue#Post1330011
post #5 of (permalink) Old 10-02-2004, 11:21 AM Thread Starter
esm
Thanks a lot!
esm is offline
post #6 of (permalink) Old 10-02-2004, 01:14 PM
Steve83's Avatar
The '76 tilt column is ENTIRELY different from the '96, so that writeup won't help.
There's no adjustment on the ignition switch, so it has to be the MLPS on the side of the transmission. The first pic is from a car, but yours looks the same. You can try to realign it, but I expect you'll end up replacing it. Click these thumbnails to enlarge.
[image]http://www.supermotors.org/getfile.php?id=81709&toggle=thumbnail&f=.j pg[/image]
[image]http://www.supermotors.org/getfile.php?id=71627&toggle=thumbnail&f=.j pg[/image]
[image]http://www.supermotors.org/getfile.php?id=71650&toggle=thumbnail&f=.j pg[/image]
Steve83 is offline
post #7 of (permalink) Old 10-02-2004, 10:51 PM
Uhhhh... I was refering to my 91' f150 ignition switch/keylock..... 76=Key switch in dash and I don't think that tilt was available then eaither [img]images/graemlins/smile.gif[/img]
post #8 of (permalink) Old 10-03-2004, 12:42 PM
Steve83's Avatar
OK The '91-older tilt column is totally different from the '92-up. [img]images/graemlins/grin.gif[/img]
Steve83 is offline
post #9 of (permalink) Old 10-04-2004, 01:20 PM Thread Starter
esm
Okay, I'll check the MLPS alignment.
esm is offline
post #10 of (permalink) Old 10-04-2004, 03:14 PM
SO THERE! Ha! Beat that one.... Nanna-Nanna-bu-bu... [img]images/graemlins/crybaby.gif[/img] [img]images/graemlins/chair.gif[/img]
havack is offline
