Want to buy 92-96 F150 4WD to tow - what to avoid? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-09-2004, 06:10 PM Thread Starter
Pete88YJ's Avatar
Hi all,
I'm looking to pick up a 'new to me' F150 to tow my jeep and trailer around. Dual axle trailer, brakes both axles, typical built jeep, currently using a 79 F250 4WD, mild 400M, NP435 to tow, but the body is just getting too rough to keep dealing with it, and I'm looking to go cross-country in the next few years, and I can't see the old girl making the trip.
So, it's time to upgrade. This year range approx. fits my budget, which is probably in the $4K to $6K range. I think I'm looking for an automatic, v8, regular ol' F150. Are there any items I should look to avoid, like certain years, or transmissions, or anything like that??
Do any of you tow with a manual trans in this year range? Is that advised? I love the NP435, but does the new stuff have as good of a granny gear, or is it as robust?
I did search, and couldn't find anybody asking for this info.
Sorry for the length, thanks for any insight!
Pete
Pete88YJ is offline
post #2 of (permalink) Old 09-10-2004, 12:52 AM
Re: Want to buy 92-96 F150 4WD to tow - what to avoid?
I'd avoid F150s as tow <nobr>vehicles</nobr>. You want the F250 or F350. 3/4 ton should fit the bill for what you are doing. The 150 is underpowered and more importantly the brakes are unadequate for heavy towing. Just my .02
BigNorm is offline
post #3 of (permalink) Old 09-10-2004, 08:03 PM
I would agree, go for the 3/4 ton. I've towed with my 93 F150, which has the 300ci 4.9 6 cyl in it and a 5 spd manual. I towed a full size trailer with a jeep on it, and I even towed a wagoneer once. It towed ok, but braking was a bit sketchy, especially with that waggy on the trailer. Go for the F250 with a V8 in it. My dad has one and it's much better for towing, the PO used it to tow a 5th wheel camper and said it was the best truck he'd towed with in his opinion.
CJ7Attitude is offline
post #4 of (permalink) Old 09-11-2004, 10:00 AM
Avoid the 5-speed it is a Mazda unit which doesn't hold up for towing.
Get a 351W and automatic. The 95 and 96 models had upgraded transmissions but the 92-94s are pretty stout. I think most of the 4x4s come with 3.55 gears which are good. Just make sure it doesn't have 3.08 gears. 94-96 have airbags.
If you have trailer brakes you will be fine stopping with a 1/2 ton. I pull an 18 ft trailer with brakes only on one axle and it brakes good. I pull a 21 ft boat without trailer brakes and pull tractors, trucks, cars on the 18 ft trailer without any problems.
My truck is a 93 351W auto 4x4 extended cab with 211,000 miles on it.
If the ONLY thing you do is tow then you could look at a 3/4 ton. The 3/4 ton does come with a good 5 speed if you want a manual.
F150 is offline
post #5 of (permalink) Old 09-11-2004, 06:49 PM
I've got a 91' f-150 2wd with 300/5speed and 2:72 gears and I have had no trouble whatsoever pulling anything with it. I've pulled trailes with and without brakes no problems I do recomend trailer brakes though. If you have a choice between the 302 and 300 take the 300 much better for towing. If I used mine for towing more I would get lower gears like 3:08 or 3:55. But its suprisingly strong considering the gears. If I can keep it up around 65/70 I can pull just about anything up a steep grade even with the AC on. As long as I am running at least 1400rpm it does great! Excelent MPG also. Other day I hauled a car 70 miles and got 18mpg I was running 70/75 with the AC on. Never had to downshift out of 5th. In my opinion a EFI 300 pulls better than any Carb'd small block.
Jacob_Royer is offline
post #6 of (permalink) Old 09-13-2004, 01:07 PM Thread Starter
Pete88YJ's Avatar
Hey guys,
Thanks for all the info. I have heard some good things about the 300-six.
I do think I'll go automatic, just for convenience. I guess it'll come down to what I find available in the 1/2 or 3/4 ton choice. Gearing is a definite thing to look at though. My trailer has good brakes, and the old 79' brakes I'm sure aren't as good as they used to be and my truck/trailer pair stops fairly well now, but brakes surely aren't a part of the package I want to be weak, so I may look more closely at the 3/4.
Thanks again for all the help. Much appreciated. [img]images/graemlins/smile.gif[/img]
Pete
Pete88YJ is offline
