Trouble starting - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-26-2004, 10:32 AM Thread Starter
Trouble starting
95 F-150 302 4x4 auto.......
Will not start unless you jump across posts on starter, have replaced selenoid am at a loss as what to try next.
Any ideas???????
Thanks
grump105 is offline
post #2 of (permalink) Old 05-26-2004, 02:31 PM
Re: Trouble starting
Unless you bought a bad starter relay I can only guess that it might be your ignition switch.
BigNorm is offline
post #3 of (permalink) Old 05-27-2004, 01:39 PM
fcarruth
I agree with BigNorm but one time I acidentally torqued the nuts too tightly and actually cracked the solenoid.
Good luck,
post #4 of (permalink) Old 05-27-2004, 01:58 PM
Pooh-Bah
WD40's Avatar
Make sure your battery cables and connections are in good condition.
Also, check the wiring/connections at the starter motor itself.
WD40 is offline
post #5 of (permalink) Old 05-30-2004, 12:35 AM
Check the condition of the wire going to the starter.If it's stiff and the wires look brittle on the end,replace it.The zone sells em cheap.Went thru a starter and a solenoid before I figured mine out.
Bill
broncobilly69 is offline
post #6 of (permalink) Old 05-30-2004, 03:08 PM
i agree with the 2 above on my 82 had the same problem turned out the wire was bad inside the insulation from the outside it looked fine but when i ohmed it out it was screwed replaced it been working fine for 2 yrs now
lal357 is offline
post #7 of (permalink) Old 05-31-2004, 12:05 AM
Het Grump
What about the on the column switch ?
Sixlitre
Sixlitre is offline
post #8 of (permalink) Old 05-31-2004, 02:20 AM
If you have a volt meter,turn the key to the start position and check for voltage at the small wire on the solenoid.If you have 12 volts,the ignition switch is good.Then check both sides of the solenoid.If your getting 12 volts across and it still won't start,got to be the wire going to the starter.If you don't have a volt meter, get one,They come in handy.
Bill
