Trouble Bleeding Brakes on '85 F150 2WD - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-21-2004, 06:22 AM Thread Starter
Journeyman
BigElecCat's Avatar
Trouble Bleeding Brakes on \'85 F150 2WD
I can't seem to get all the air out of many brake system. I remember seeing something about a plunger in the bottom of the proportioning valve that need to pulled out and held in place with a clip. Anybody know anything about this?
BigElecCat is offline
post #2 of (permalink) Old 05-21-2004, 10:04 AM
Re: Trouble Bleeding Brakes on \'85 F150 2WD
What is you current procedure?
havack is offline
post #3 of (permalink) Old 05-22-2004, 12:22 AM Thread Starter
Journeyman
BigElecCat's Avatar
I have Russell one-way bleeder valves in the rear wheel cylinders and front calipers. I start at the right rear, pump the pedal until the fluid in the master cylinder is low, fill the master and repeat. I do this several times then move to the other rear wheel. Then I go to the right front, then the left front. The brakes feel fine when I'm done, then after about 100 miles they go weak, spongy and grabby. I'm not losing any fluid. I may have damaged the right rear cylinder when I changed out the park brake cable. That's when this problem started.
post #4 of (permalink) Old 05-22-2004, 12:32 AM
Who the heck was the engineering genius [img]images/graemlins/cussing.gif[/img] that thought up putting the bleeders pointing straight into the hubs ! So GD close you can't get a bleeder hose on !
The Ford light must have been a little dim that day !
Sixlitre
p.s./
Try cracking the farthest screw only slightly, pumping it a couple of times and letting gravity take over for a few minutes. Just check the master once in a while. Worked for me a few weeks back and I'd just changed the the front hoses, lines and calipers.
Sixlitre is offline
