Warn Premium Question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-01-2003, 07:56 PM
I've searched through all the threads and couldn't find any discussion on my question. I just put some Warn premium's in my 1994 Bronco. It was a textbook install and very simple and easy for my second time to go through this. However, there seems to be a very very slight amount of play between the cap and the hub (I'm talkin very slight lik emaybe half a centimeter). I've re-torqed all the cap screws and they were fine. Everything is tight, 4wd works with no noise, hubs turn easily, etc. I presume this is fine, but it seems to me that may allow for some dirt and/or water to enter inside. I also presume it is fine as I've been running it since Saturday and I don't see any signs of grease seeping out anywhere. Never seen this before, but then again never really paid this much attention to one before either!
post #2 of (permalink) Old 10-01-2003, 08:58 PM
Re: Warn Premium Question
If the cap that has the lock in it doesn't fit on the rotor tightly then you did somin' wrong. No other way.
havack is offline
post #3 of (permalink) Old 10-01-2003, 10:08 PM
was there a o-ring on the dial cap? mine are tight where i have to use a thin screw driver to pry it off all due cause of that o-ring. btw did you use neverseize on your cap screws?
93bronco is offline
post #4 of (permalink) Old 10-02-2003, 07:11 AM
I guess I will pull the caps off this weekend and look at everything again. I just can't imagine what though cuz everything worked so perfectly as far as the install - hub assebly slide on beautifully, snap ring went in just fine and the lock snapped right into it's groove. Yes, there were brand new o-rings and I used them. I however did not use antiseize. Do the cap screws tend to seize up? My stock ones came off just fine.
post #5 of (permalink) Old 10-02-2003, 10:48 AM
I don't think siezing is a problem with the Warn's but you can never be too safe. Those lil buggers can be a pain when they snap off or worse break your allen wrench. [img]images/graemlins/cussing.gif[/img]
BigNorm is offline
