Shot axle pivot bushing - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-23-2003, 07:42 PM Thread Starter
ever since I got my bronco august of 02 I've been wondering why the hell my right tire leaned and my steering would be fine one second, then really screwed up when I hit a pothole or bump, checked my balljoints, they were good, today I was gonna check my bearings, well when I took off the tire, I grabbed the hub and started pushing/pulling it all kinda ways and discovered that my axle pivot bushing it SHOT!, $8 for a new one from the zone, question is what will I need to do to replace it? remove my passenger side suspension, and disconnect the radius arm? or what? I figure it's gonna be a real pita, so I may as well change the drivers side too while I'm at it darn ttb... [img]images/graemlins/chair.gif[/img] [img]images/graemlins/AR15firing.gif[/img] TTB
TheBeast is offline
post #2 of (permalink) Old 09-23-2003, 08:19 PM
Re: Shot axle pivot bushing
I wouldn't put anything from the zone on my vehicle [img]images/graemlins/chair.gif[/img] [img]images/graemlins/cussing.gif[/img]. My choice though. Try NAPA. Yes you'll have to disconnect a few things... -Bob
slickerthanyou is offline
post #3 of (permalink) Old 09-23-2003, 09:20 PM Thread Starter
[img]images/graemlins/crazy.gif[/img] that's gonna be fun.....thanks for the pic, now I know what I'm in for
TheBeast is offline
post #4 of (permalink) Old 09-23-2003, 10:49 PM
You don't have to take sh*t apart. It's actually a very simple job. There are several posts here about it. Just put a jack under the axle, give a tiny bit of pressure, pull the pivot bolt, and let the jack down slowly. I like to put some jack stands loose under the frame just in case.
Hard part is getting the factory bushing out of the axle. Drill a bunch of holes in the rubber and sawzall/beat it out. Whatever it takes. Put the new one in with silicone grease.
burntPiston is offline
post #5 of (permalink) Old 09-24-2003, 12:44 AM
muddybronco's Avatar
If you loosen the lower coil spring retaining nut you should be able to pull the beam clear of the brackets to change those bushings. I used a BFH and lots of swearing to replace mine but a balljoint press (borrow from autozone) would make it quite easy to get back in. Getting them out takes creativity and yes some swearing too [img]images/graemlins/grin.gif[/img]
muddybronco is offline
post #6 of (permalink) Old 09-24-2003, 08:43 AM Thread Starter
thanks for the info guys, hopefully I'll get those bushings and change them next week, when I do I'll get a pic of the shot one, I'm still in awe over the shape it's in
TheBeast is offline
post #7 of (permalink) Old 09-24-2003, 07:20 PM
That's why I said I did it the hard way! I was still learning this TTB - at this time so I decided since I went that far I should just put new springs [lift] on and the drop brackets... Bob [img]images/graemlins/chair.gif[/img]
post #8 of (permalink) Old 09-25-2003, 01:18 AM
me too [img]images/graemlins/smirk.gif[/img]
<img src=http://tellico.off-road.com/wwwthreads_uploads/1192840-pivotsux.jpg>
