Please Some HELP From The EFI Gurus, Injector ?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-09-2003, 11:28 PM Thread Starter
I was wondering if you guys could help me out here. The past couple of weeks my truck has been running like AS* on and off.
And yesterday she started running bad and it stayed that way. It feels like one of my cylinders is not firing. First I checked all the plugs and all are running fine except #1 cylinder. It was black and fouled out. I then changed the spark plug wire and spark plug and made sure it had spark. The spark checked good, No problem there.
So then I let it run for a couple mins while I wiggled all sorts of wires and sensors. And then I noticed a heavy fuel smell coming from the exhaust. I looked down at the passenger side tailpipe and saw some light bluish smoke coming out w/ a heavy smell of unburned fuel. (It was almost like I was down at the race track w/ that fuel smell that makes your eyes water)
So then I thought...... [img]images/graemlins/cussing.gif[/img] GREAT! cylinder #1 is shot.
I then did a compression test on all cylinders. All of them including #1 were at 150 psi. + or - 5psi.
So the next step (I think) is to pull the #1 cylinder fuel injector. Any thoughts guys? They would be greatly appreciated.
*1991 5.0L w/ 24# Ford Motorsport Injectors*
Jerry D.
DVLDOG458 is offline
post #2 of (permalink) Old 09-10-2003, 01:19 AM
Re: Please Some HELP From The EFI Gurus, Injector ??
they make a check light that you plug into the electrical connector that goes to the injector and it tells you if you are getting a signal or power pulse there.
80BRONCO is offline
post #3 of (permalink) Old 09-10-2003, 03:15 AM
muddybronco's Avatar
you could swap that injector with the next cylinder and see if the problem follows the injector... easy enough [img]images/graemlins/smirk.gif[/img]
muddybronco is offline
post #4 of (permalink) Old 09-11-2003, 02:31 AM Thread Starter
Thanks guys!
A buddy of mine that owns a speed shop is gonna lend me a 24# injector just to see if that is the problem.
I'll keep you posted on how I make out. I hope this is it!
Jerry D.
post #5 of (permalink) Old 09-11-2003, 10:53 PM Thread Starter
Well, No luck today, even with the new injector.[img]images/graemlins/confused.gif[/img]
I went over everything again, spark (cap rotor plug wire),compression [150 psi),and fuel......
Now, I'm not getting any fuel to the #1 cylinder!
I checked the resistance on the injector. I think it was like 5 ohms. It's gotta be the injector wiring harness, or the computer.
I checked the harness for any shorts.....nothing!
I even turned the ignition on and checked the voltage to the injector plug, and I'm getting power.
Does anyone know what the voltage should be?
Any other thoughts guys?
post #6 of (permalink) Old 09-13-2003, 02:07 AM Thread Starter
My injector ohm reading was 14.1
I wasn't sure last night when I posted. Sorry for the confusion.
Well, today I went and bought a noid light. It works like a charm!
It told me that my #1 injector plug is not getting any pulse.
So, I ordered a remanufactured computer. It should be here Monday. I'll keep you posted.
One other quick question. When I ordered the new computer I used the code on the side of the computer (A3M1)
I know this isn't the stock computer number for a 1991 F-250 w/ 5.0L. Being that I converted over to massair. A new computer came w/ the Ford massair kit. I was just curious if anyone knew what vehicle that code is used for?
post #7 of (permalink) Old 09-13-2003, 10:58 AM
Check out Ford Fuel Injection for some more answers. You can go to FSB and contact Fireguy50. The fisrt site I posted is his site.
lookinfurfun is offline
post #8 of (permalink) Old 09-14-2003, 06:54 AM Thread Starter
WOW!
Lots of good info there, Thanks.
post #9 of (permalink) Old 09-16-2003, 06:23 AM Thread Starter
Well, another BAD day. New ECM installed..........still no good.
I guess it's time to rip the Ford mass-air conversion overlay harness off again and really look it over.
Any other suggestion guys?
Jerry D. [img]images/graemlins/cussing.gif[/img]
post #10 of (permalink) Old 10-08-2003, 05:15 AM Thread Starter
UPDATE:
Well, I sent the mass-air conversion overlay harness back to Ford Racing and they tested it and told me it was bad.
I should be recieving a new one by the end of the week..............Wish me luck! I'm gonna need it.
Jerry D.
