Mounting Radius arms to a 86+ D60 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-05-2003, 10:24 PM Thread Starter
well, i knew lots of you guys are wondering how it was going. its going slow as i have been working on other things as well.
First, on the rad arm mounts. i bought new wedges since i didnt feel like using my old screwed up ones..
FYI, the rad arm wedges have to be inboardeed 1/2-3/4" on each side do to the tube stops shorter, but i dont think it is a big deal.
the passanger side is easy. the driver side is some work.
first you need to grind the spring pad on the casting round
next you need to make your wedges fit
start grinding!
the problem pic
spring pads in the way, and the wedge is to wide
#1 fixed
the wedges are still to wide though
grind it!
i keopt checking it to see what part of the wedge wasnt fully seating and the high spot by smearing grease on the axle casting where the wedge will partially sit
the mark left on the wedge then
shows you where to grind more
how you want it to fit
total amount removed
use a solid d44 to compare it to to set the stuff right
the easy passanger side, you also had to remove the spring pad, and the plate the U bolts run through on this side.
how it fits on the driver side
the hose clamps make a kickass way to hold it while you set your caster. my catse risnt set yet, but ithink i can set it th best i can off that d44, then i can acually put it under the truck and bolt it on using just the hose clamps to hold them toghther, and then put my old coils in just to recheck it at ride height.
then the coils come out and get thrown away for my airbags. [img]images/graemlins/beach.gif[/img]
BurnedBronco is offline
post #2 of (permalink) Old 09-06-2003, 05:31 AM
Re: Mounting Radius arms to a 86+ D60
WOW!!! Where did you get the new wedges from?
MY2ND78 is offline
post #3 of (permalink) Old 09-06-2003, 08:36 AM Thread Starter
James duff sells new ones for like $80 to my door.
jeffs graveyard wanted $45 for used ones that where rusted to hell and still attached to a d30 tube.
post #4 of (permalink) Old 09-06-2003, 08:33 PM
froggy
Where did you pull that 60 off of? Looks like you got your work ahead of you.
post #5 of (permalink) Old 09-06-2003, 09:34 PM
early bronco c wedges [img]images/graemlins/laugh.gif[/img] let em guess it was leaf sprung before.
McDerry is offline
post #6 of (permalink) Old 09-07-2003, 09:59 PM Thread Starter
oh, so nice
i figured out i need to order some 4* C bushings to make it work perfect with 5* camber. my 2's in it now arent enough, and my 7's where to much.
good driveline angle
once i get the bushings mounted up in there ill weld the wedges to the tube and then recheck it, and then ill rip the coil towers out and start to work on the bags
hey blown, will this be enough travel?
my limiting factor is going to be the trac bar and driveshaft
post #7 of (permalink) Old 09-24-2003, 09:42 PM
Looks like SuperFord is on the fritz again....
Burned...can you post the pics again? I've got a few guys that want to see how it's done.
MY2ND78 is offline
post #8 of (permalink) Old 09-24-2003, 09:51 PM Thread Starter
wow, talk about odd pics!
there all in my superford, the captions arent up yet, but you get the idea.
i reloaded them all last night since superford deleted them, so ill get it updated when i have some time.
post #9 of (permalink) Old 09-25-2003, 01:34 AM
muddybronco's Avatar
oh, so nice
<img src=http://www.superford.org/getfile.php?id=85338&amp;toggle=fullsize&amp;filen ame=DSC01209.jpg>
that's too good! [img]images/graemlins/chairfall.gif[/img]
muddybronco is offline
