body panel replacement - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-01-2003, 09:01 PM
well, my friend has a race car shop that has all the equipment anyone would need to repair a truck. but i dont know the right way to replace quarter panels. like i have heard drilling out the original spot welds, but when i do new spot welds wont it be less stable...do to the loss of surface area with the holes. i know lots of people do body panel replacement.. any pointers?
post #2 of (permalink) Old 09-01-2003, 09:30 PM
Re: body panel replacement
i'm not a body man or anything like that but do work with spot welders at work and when theres a screw up we only drill out most of the top piece of material and then using a chisel to split piece's leaving the bottom piece intact im not sure if that how the body shops do it but it works for us at work
93bronco is offline
post #3 of (permalink) Old 09-01-2003, 11:49 PM
SMACDU
I recently repaired the rust on both sides of my quarters using patch panels from RayBuck. I used an air-cutoff tool (not an air chisel) and cut out a square section a little smaller than the patch panel itself. I then used an air crimper on the sheet metal of the truck and then cut the patch panel to fit within a 1/8-1/4. I then used a MIG to weld continuously around the entire panel rather than spot welding (stronger). I then welded in new wheel houses purchased from Jeff's Graveyard.
Any questions, you can e-mail me direct.
Good luck
Shawn
post #4 of (permalink) Old 09-02-2003, 04:33 PM
The proper way is to get a spot weld removal too (special drill bit). Alternately you can use a small drill bit and cold chisel the rest.
havack is offline
