Re: AOD to np205?
You might try a later-model bw1356 case with the updated case casting that keeps the oil pump from moving around. What are you doing that's causing the chain to stretch, because I've beat the crap out of mine in the mud and on rock and not had one mechanical problem with the case. As for the 205, you could notch the aod tail housing but you still need the boss on it for the shifter, and I'm not sure if a C6 tail housing would bolt to the AOD.. maybe. Somebody else probably knows, but personally I'd find a newer BW case and keep the 2.7:1 low range [img]images/graemlins/40BEER.gif[/img]
