Bit technical on CAMs - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-27-2003, 11:51 PM Thread Starter
Anybody got any good reading on changing from hydraulic to solid cams? My 76 302 needs a cam and all I have is the solid hipo cam.
havack is offline
post #2 of (permalink) Old 08-28-2003, 05:02 PM
Pooh-Bah
WD40's Avatar
Re: Bit technical on CAMs
Hmmm. Changes.
1) Lifters. (that's rather obvious)
2) Adjustable valve train. (to facilitate adjusting the valve lash)
I'm guessing your current rockers are "pedestal mount-positive stop" type. (Torque the stud nut on all the way. No adjustability.)
You'd need to get some self locking nuts. Like these, or these, or this kit if you have 5/16" studs.
I'm also guessing, your rockers are the "rail type". (They have “ears” on the valve tip end of the rocker where it contacts the valve.)
Not recommended for hi-po use.
However, they could work with the adjustable nuts, if you had to do it that way.
3) Valves will need to be changed.
You need the type that have a .250 hardened "tip" on the valve stem.
If you use the stock valves, with solid lifters, the rocker arm will hammer the tip, and........boom! [img]images/graemlins/shocked.gif[/img]
Unfortunately, it's not a quick and easy swap from a hydraulic to solid cam.
The best way by far IMHO, is to mill the stud bosses, and install 3/8" studs and guideplates.
Get the newer style (non rail type) rockers, or better yet, especially with a solid cam, rollers.
Hardened pushrods will also be required, if using guide plates.
Here's some related reading.
Erson Cams Ford technical information.
Comp Cams Ford technical information. (go to pages 62-65) - (takes a bit to load [img]images/graemlins/crazy.gif[/img])
WD40 is offline
post #3 of (permalink) Old 08-28-2003, 11:41 PM Thread Starter
Went with Edelbrocks Performer plus from Summit for $131 to my door. Cheapest I could get it in town was the Zone for $150 plus tax.
Now to find a home for the solid hipo cam I have...Takers anyone?
havack is offline
post #4 of (permalink) Old 08-29-2003, 04:56 PM
Pooh-Bah
WD40's Avatar
Went with Edelbrocks Performer plus.
Didn't want to do all that work to get the solid in?? [img]images/graemlins/tongue.gif[/img] [img]images/graemlins/grin.gif[/img]
Don't know off-hand whom may want that cam in this area, but I can check.
What are the specs?
Sounds like you made the right choice, since the hyd cam was cheaper than all the mods you would have to do.
WD40 is offline
post #5 of (permalink) Old 08-29-2003, 05:37 PM Thread Starter
I think:
Duration Intake 310 Exhaust 310
Intake Centerline 108
Lobe Seperation 114
Overlap 82
IVO 47
IVC 83
EVO 95
EVC 35
0.050" Timing
Duration Intake 228 Exhaust 228
IVO 6
IVC 42
EVO 54
EVC -6
Lift Intake 0.477 Exhaust 0.477 (with 1.6:1 Rocker)
havack is offline
post #6 of (permalink) Old 08-29-2003, 05:46 PM
Pooh-Bah
WD40's Avatar
Hmmm.
"Big um" top end cam.
Not for your average off-roader.
In your Mustang though....... [img]images/graemlins/burnout.gif[/img]
WD40 is offline
post #7 of (permalink) Old 08-30-2003, 11:11 AM Thread Starter
It is the stock cam for the high end mustangs that shelby used.
havack is offline
