Help - Pinging and TPS issue - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-21-2003, 09:47 AM
sbrich
'88 302 EFI AOD
Recently started expeiencing a pining and lack of performance around 1800-2200 RPM range.
Changed or did the following
TPS
EGR
EVP
O2
PCV
Cleaned Throttle Body
Fuel Filter
Cap/Rotors/Wires (Accel)
AC Delco Rapid Fire Plugs
Premium Gas
When I checked the TPS (old one), voltage was reading 4.8 all of the time, So I changed it. Well I replaced it and checked the voltage again and it still reads 4.8 [img]images/graemlins/confused.gif[/img]. Pulled the codes yesterday and with the new TPS I had a 63 code.
If I wanted to check the vacuum what is the best way to do so?
Any ideas on what else I can do concerning the pinging/lack of performance and what I might be doing wrong with the TPS would be appreciated.
Scott
post #2 of (permalink) Old 08-22-2003, 10:30 PM
Steve83's Avatar
Re: Help - Pinging and TPS issue
The TPS has 3 wires, and you have to test the voltage across the correct 2 wires. The Haynes manual shows where to put the meter probes. What manual are you using?
Read these:
http://www.ford-trucks.com/forums/sh...hreadid=112293
http://www.users.bigpond.com/ergoff/vac1.htm
Steve83 is offline
