Nasty vibration and a loose rear pinion nut. 10.25 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-13-2003, 09:22 PM
Biggie_Truck
I was getting some nasty vibration coming from the rear driveline. When I checked it out the pinion nut was loose. I torqued it down to 160 ft lbs. It was o.k. but then after 25 miles or so it happened again.
Now I know to torq the nut until the preload is about 8-14 in.lbs. and to use red loctite.
Does this axle (10.25) have a crush sleeve. I dont think it does right? I know if it does Ill have to replace it. Just need to know. I could pull the seal but Im lazy and its freakin hot out. [img]images/graemlins/tongue.gif[/img]
Buy the way. No noise yet.
post #2 of (permalink) Old 08-14-2003, 12:45 PM
Shilo
Re: Nasty vibration and a loose rear pinion nut. 10.25
This is the #1 biggest most common problem with the 10.25. It DOES have a crush sleeve, yes. Replace it with a solid spacer ASAP (I should heed my own advice).
10.25s have a nasty habit of eating pinion bearings, mine runs hot as it is, around 150 degrees at the pinion snout on the highway. The 14 bolt in my van runs at 115 degrees under the same conditions (IR guns are cool!)
post #3 of (permalink) Old 08-15-2003, 02:37 PM
Yea, I thought it did. So can your solid spacer trick be used for the 8.8 then? It uses the same setup as the 10.25 (just not as big).
TheJuice is offline
post #4 of (permalink) Old 08-15-2003, 04:59 PM
Shilo
My understanding is that you can also use a solid spacer in the 8.8, yes. I believe it's a 9" application, but fits most Ford rears (don't quote me).
