capacity of front, rear diffs and t case? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-08-2003, 03:28 PM
96XL
does anyone have link to or know how many quarts/ pints the front and rear diffs and t-case take? thanks for the help guys!
post #2 of (permalink) Old 08-08-2003, 03:32 PM
broncoman
Re: capacity of front, rear diffs and t case?
Got your owners manual? All the info in there.
post #3 of (permalink) Old 08-08-2003, 03:34 PM
96XL
sorry my truck did not come with one (bought used)
post #4 of (permalink) Old 08-08-2003, 04:02 PM
Haynes manual should have the info also. Just add 'til it comes out the fill hole.
burntPiston is offline
post #5 of (permalink) Old 08-08-2003, 04:17 PM
96XL
thanks, i just did not want to buy to much and then have to return what is left over. (i am kinda far from a parts store)
post #6 of (permalink) Old 08-08-2003, 05:37 PM
Pooh-Bah
WD40's Avatar
IIRC, I usually get 4 qts to do both the front (Dana 44) and rear (9"), and end up with a partial one left over for topping up.
As was mentioned, just fill to the bottom of the plug hole.
WD40 is offline
post #7 of (permalink) Old 08-08-2003, 06:05 PM
Front (to the bottom of fill hole) 3.8 pints
Rear 8.8 (1/4" to 1/2" below filler hole) 5.5 pints. Don't forget additive if equipped with crap-lock
BW1356 2 quarts Mercon auto tranny fluid.
TheJuice is offline
post #8 of (permalink) Old 08-08-2003, 06:24 PM
Crap loc's better than no loc IMO! My crap loc in the D44 has worked awsome for me in the past. Surprisingly so. I do believe that this is probably the exception and not the rule. I would never spend money on this upgrade but if it's already in there I feel it's better than being open. [img]images/graemlins/smile.gif[/img]
BigNorm is offline
post #9 of (permalink) Old 08-08-2003, 07:42 PM
they work good till ya get your tires up in the air they the tires in the air spin great has happened to me twice last time i had to winch (which worked fine ) so i solved the rear my mini spool got to the house yesturday should be in by oct.
lal357 is offline
post #10 of (permalink) Old 08-09-2003, 10:53 AM
96
Unless you commute to work up streams, like lal357(lots of changes due to water contamination), go to fully synthetic 75W90 gear lube and fully synthetic Castrol mercon tranny fluid. I get my gear lube at any Dodge dealer, it's still about $9.00/quart Canadian (American pocket change) and it's clean as a whistle when I dump it/vacuum it (front axle) every year or two.
Sixlitre
p.s./
WD-40 is spot on the numbers I use for buying amounts.
Sixlitre is offline
