Dead Bronc-ignition module? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-03-2003, 03:43 PM Thread Starter
The other day I was drivin home and my truck died 1/4 mile from home. I just shut off, I pushed it home, the battery and starter are fine, I can hear the fuel pump buzzin. It just cranks over and doesn't start, sounds good when It cranks over. Could it be anything other than the ignition module, coil, maybe crankshaft position sensor? The ignition module has been changed once before.
bucknbronc is offline
post #2 of (permalink) Old 08-03-2003, 06:31 PM
Re: Dead Bronc-ignition module?
does it have something under the dist.(help me out guys forgot the name ) i had a 89 and that peice just went out all the sudden i replaced it and it went out about 3 month later was told they do that sold it and it has been running good ever since
its somekind of module but i foget the name cost 20-30 dollars
lal357 is offline
post #3 of (permalink) Old 08-03-2003, 06:41 PM
Are you referring to the TFI module?
If that was going bad, then his truck would stall when it gets hot, and not run properly (or at all) until it cools down again. If it all out failed, i would imagine that the truck wouldnt start
reptillikus is offline
post #4 of (permalink) Old 08-03-2003, 06:59 PM
BRONCOMANIA's Avatar
lal357,
are you thinking of the PIP pickup sensor inside the distributor?
possibly, also could be yuor coil OR plugged fuel filter. first determine if you have spark and/or fuel...
BRONCOMANIA is offline
post #5 of (permalink) Old 08-03-2003, 07:50 PM
no it wasnt the coil or any of those it was held into the bottom of the dist. by 2 screws and you have to put some di-electric grease on the plate and the specail tool for the screws is a life saver mine jsut went out no notice at all the first time in the middle of the woods
lal357 is offline
post #6 of (permalink) Old 08-03-2003, 11:36 PM
muddybronco's Avatar
FORD used to put those TFI modules on the dist itself but then moved them to the fender with a hd heatsink on them because they got so damn hot! i don't know what year they changed it but that's probably the source of the confusion... if there's a way to move it to the fender, I would!
muddybronco is offline
post #7 of (permalink) Old 08-04-2003, 02:43 PM Thread Starter
It was the ignition module, I just replaced it. it's located on the side of the distributor w/2 screws, didn't know I needed a special tool until none of my sockets would fit. I ended up pullin the dist. because the intake manifold was in the way. When I put it back the timing was off, but I got it close to where it was before, i'll just take it to a shop and pay another $40.00 buckz for them to fix my mistake.
[img]images/graemlins/chair.gif[/img]
post #8 of (permalink) Old 08-04-2003, 07:11 PM
so did they change the dist. on the laterz with the remote module or is it just a special wiring harness???
might be something to look into, for us earlier TFI-IVs guys [img]images/graemlins/wink.gif[/img], being that my module has been in there for 11 years already, i had considered keeping a spare [img]images/graemlins/smirk.gif[/img]
