EFI to carb swap - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-15-2003, 06:25 PM
EFI to carb swap
Alright, did a little searching and really couldnt find a definitive answer about what is necessary to switch from efi to carb. I have a 90 bronco with a 302 and 200,000+ thats never been rebuilt. I've decided to swap in a 351w with a c6, but am still not positive which combination would be better for mild performance. I'll probably upgrade pistons, heads, mild cam, and intake. I know the speed density that is on the 302 right now doesnt adjust well to changes. So, would the 351w with a mass air or carb be the better choice? Any opinions are appreciated. Thanks.
post #2 of (permalink) Old 05-15-2003, 10:42 PM
Re: EFI to carb swap
Fuel Injection is always better than a carb. Especially on a wheelin' rig.
BigNorm is offline
post #3 of (permalink) Old 05-15-2003, 10:49 PM
I agree with BigNorm. If you had a carb and wanted to go FI, I think that is the more complicated way. I would look toward doing the mass air. I do know that it is not a cheap way to go either. But I'll take the FI over carb any day, especially if you are already equipped. Try to keep it simple.
TheJuice is offline
post #4 of (permalink) Old 05-16-2003, 12:12 PM
Carbs suck when wheeling. They ussually spill too much fuel at extreme angles and flood the moter killing it or killing power because it's running way rich.
My 2 cents: Stroke the 302 to a 347 keep the speed density, try it. If it does not work well change to MAS. Pricey and can be found through JEGS or Summit. I put a blower on my 302 with Speed density. It ran fine off idle, but I couldn't get the idle I wanted. I did end up doing the conversion too mas. The kit came with a 50mm meter bore and I went larger to 70mm and 30 lb injectors. Now I got the thing to idle well, but noticed very little performance change off idle. Something like $1200 later, I don't think I would have converted it knowing what I do now. I should have researched/tried an aftermarket map sensor that may solve any speed density problems you have. I don't know if it would work. You can also squeeze more out of your injectors by adding another fuel regulator. Just some ideas.
I am running a mild cam. I've heard if you go too radical Speed density won't handle the change. Competition cams has a speed density camshaft that is supposed to increase perf. without screwing up the speed density. If you get too radical with a cam you lose the low rpm torque you need for towing and wheeling. I know I mad ethat mistake in my 84 with comp cam 268 duration. It spun up to nice rpms but at the loss of low rpm grunt for crawling around. Good for high revs in sand/mud/cinder climbing but not elsewhere.
Blown is offline
post #5 of (permalink) Old 05-16-2003, 01:49 PM
If you stay with SD, you can change the cam as Blown has said. You need to make sure there is enough vacuum with this cam. This is where the idle issue comes in.
You can also get the GT40P heads that cam off of the Exploders. This is a nice upgrade that I have been looking into too....but it's far down the list of things to do. You might want to look at what some of the 'stang guys are doing with their SD motors. Check out some of those forums.
More than likely you'll need a chip for all of the mods too. It seems like the Diablo chip seems to be one of the better ones out there because it works throughout the powerband and not just at WOT like Superchips or others out there.
lookinfurfun is offline
post #6 of (permalink) Old 05-16-2003, 09:48 PM
To swap to a carb you'd need a low pressure fuel pump,new intake manifold and carb.Plus the tranny linkage for an aod(if thats what you have).Throw in a duraspark ignition set up too.Not cheap unless you raid the parts off a donor vehicle.EFI is better for wheeling and gas mileage.However it does'nt take a rocket scientist to re jet a carb or set float levels etc.Tuning a computer (especially SD) hopped up motor can be a major pita,it takes bucks(mass air, computer tune etc) to get it right.Pick your poison.For an offroad vehicle I'd stick with efi and make mild mods.If you want major HP swap to carb and let er rip.
CB
broncobilly69 is offline
post #7 of (permalink) Old 05-17-2003, 01:25 AM
I'm missin' out on some lingo here. What is SD? [img]images/graemlins/crazy.gif[/img]
BigNorm is offline
post #8 of (permalink) Old 05-17-2003, 11:17 AM
SD=Speed Density
