clutch trouble - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-14-2003, 12:45 AM
clutch trouble
The truck is a 1990 F-350 4x4, internal slave cylinder,zf tranny. When I bought it the tranny was out because the clutch was wasted. I put a new clutch disc, through out bearing and pressure plate in and installed the tranny. When I filled up the master cylinder and tried bleeding the system nothing came out the bleed screw. i took the line off at the master cylinder only a little bit dribbled out. When I depress the clutch pedal nothing happens and the master cylinder doesn't empty. I suspect I need a new master cylinder or am I totally missing something?
post #2 of (permalink) Old 05-14-2003, 02:00 PM
Re: clutch trouble
Sounds like your on to it, unless the pedal linkage is not pressaing in on the master. You should have brake fluid squirting out of the master. I heard from some that when you put a new slave in it is sometimes difficult to bleed it. I did not have a problem with mine, but it did take some vigerous stomping on the pedal to get the air out. good luck, I think you answered your own question.
Blown is offline
