my f-150 is dead no electrical power solved - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-01-2003, 10:28 AM Thread Starter
i'm stumped i went to crank my truck and nothing not even the head lights come on but i can jump across the starting relay and it will turn over the engine but not run
any ideas where to go now [img]images/graemlins/confused.gif[/img]
lal357 is offline
post #2 of (permalink) Old 05-01-2003, 02:07 PM
Re: my f-150 is dead no electrical power
Check your ground connections at the battery and chassis.I have seen the ground cables get brittle with age and go bad.
Billy
broncobilly69 is offline
post #3 of (permalink) Old 05-01-2003, 02:26 PM
Novice
On the early '80's Fords there is a ground wire at the solenoid, on the fenderwell. Without it, you have no power to anything. Have you replaced the solenoid? If so, it's an easy wire to miss.
firegod33 is offline
post #4 of (permalink) Old 05-01-2003, 05:21 PM
I had something similar happen on my truck....
If i turned the key to the Start position, nothing would happen, but if i had somebody jump the relay while i turned the key i could start it. It turned out that the Neutral Safety Switch on the trans went bad. You can try jumping the powerlead around the switch to test to see if its still working or not
reptillikus is offline
post #5 of (permalink) Old 05-01-2003, 06:00 PM Thread Starter
turned out to be the pos wire to the sol. it was corrioded (<-?) just inside the insulation guess thats what i get for leaving it parked for 5 months thanks for the input / help
larry
lal357 is offline
post #6 of (permalink) Old 05-01-2003, 06:29 PM
Re: my f-150 is dead no electrical power solved
WELL I HAVE A 90'F-150 AND I'VE HAD ALMOST EVERYTHING GO WRONG BUT NOT QUITE WHAT YOU TALKING ABOUT BUT MY ADVICE IS TO CHECK ALL THE WIRES THAT HAVE ANYTHING TO DO WITH THE POWER TO AND FROM YOUR BATTERY AND IF IT TURNS OVER AND WONT START THEN YOU SHOULD CHECK OUT YOUR FUEL PUMP IT MIGHT BE MIGHT BE A RELAY OR SOMETHIG. I HOPE IT HELPS.
post #7 of (permalink) Old 05-03-2003, 05:57 PM
You don't have to YELL! [img]images/graemlins/shocked.gif[/img]
slickerthanyou is offline
