engine swap kit - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-28-2003, 11:55 PM Thread Starter
engine swap kit
I've just finished installing my 3" homemade body lift and I'm starting to think of the engine swap that i have in mind. I've got a 302 now and fixing to start building a small block 400. Where can I get the "kit" from (motor mount brackets, etc.) Thanks [img]images/graemlins/givemebeer.gif[/img]
crossroads is offline
post #2 of (permalink) Old 04-29-2003, 03:12 AM
Novice
Re: engine swap kit
There is no "kit" that I'm aware of. Start researching, then finding/fabbing what you need. What year is your rig?
firegod33 is offline
post #3 of (permalink) Old 04-29-2003, 07:31 AM
Aprentice
Re: engine swap kit
If anybody has one it would be Advanced adapters. If they don't have it you'll probably have to go the custom route.
Buffy is offline
post #4 of (permalink) Old 04-29-2003, 07:43 AM
Re: engine swap kit
I don't think there is a kit for a Ford Small block 400 but you can get a good stroker out of the 351W
BigNorm is offline
post #5 of (permalink) Old 04-29-2003, 09:33 AM
Re: engine swap kit
The 400 was available in 80 and 81 Broncos. If you can find a cooperative Ford parts guy, get him to look up the part #'s for you. If not, try hittin' the bone yards for a 80 or 81 Bronco w/ 400 for the donor parts you need.
MY2ND78 is offline
post #6 of (permalink) Old 04-29-2003, 06:24 PM
BRONCOMANIA's Avatar
Re: engine swap kit
Like my2nd78 said, get all you need fom a pre-82 bronco-f150, the bellhousing bolt pattern is also different as is the exhaust so you might as well get it all in one shot from the boneyard...
BRONCOMANIA is offline
post #7 of (permalink) Old 04-29-2003, 09:10 PM
Re: engine swap kit
Read my post carefully. I said there is no Ford 400 small block. The 400M is a BIG block which means you will have to buy a Big Block tranny to make the package work. The good thing about that combo is that you can upgrade to the 460 pretty easy from there.
BigNorm is offline
post #8 of (permalink) Old 04-30-2003, 08:04 AM Thread Starter
Re: engine swap kit
My bad Norm, the block I'm referring to is the 351m. I think I can get the motor mount brackets from a boneyard, what else should I look for while I'm there. Thanks [img]images/graemlins/40BEER.gif[/img]
post #9 of (permalink) Old 04-30-2003, 02:59 PM
Pooh-Bah
WD40's Avatar
Re: engine swap kit
Same things you'd need to look for if it was a 400M.
351M is also considered a "big block" as far as trannies go. [img]images/graemlins/crazy.gif[/img]
351M, 400M, and 460 all have the same bellhousing pattern.
WD40 is offline
