voltage question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-28-2003, 09:53 PM
voltage question
i finally got around to replacing the power lead for my winch the other day. got it all wired up and re spooled the cable. i have noticed that my voltage guage is reading higher than before i wired the winch up. i could understand lower voltage due to a short or something but higher? i have not checked it with a volt meter so i do not have a base line(before install) to compare it with. i have added acceories to the electrical system ie. 8 hide-a-way strobes, vhf radio, sciren/pa. i did not have any problem with only these installed. any ideas? is there a built in voltage regulator inthe alternator that could be shot?
post #2 of (permalink) Old 04-29-2003, 05:33 PM
Re: voltage question
Yes, the voltage regulator is inside the ALT. for your year, as to it being bad because it reading too high? what is the actual out put of your ALT? if it's between 12-14v it's good. Mine reads 13.27 i have the same ALT as you but it's a 140amp'er.
slickerthanyou is offline
post #3 of (permalink) Old 04-29-2003, 07:06 PM
beerstash
Slickerthanyou--what kind of ALT do you have? I need one around that neighborhood of 140. Thought about the 220 from Powermaster in Knoxville,TN-they also have the 140 I'd been looking at. Mean Green had a couple of ALT's but there for CJ's [img]images/graemlins/cussing.gif[/img] Oh well. Any help is appreciated as always.
post #4 of (permalink) Old 04-29-2003, 07:20 PM
Here is a Pic, I got it at a local [img]images/graemlins/frown.gif[/img] (no longer in business shop). It cost me $100 + my old one.
post #5 of (permalink) Old 04-29-2003, 08:21 PM
ok, left the bronco at home all day(developed a new squeak from the engine compartment) the bat was 12.45 volts. i started her up and the battery measured 14.8 volts. checked at the power distrubition for the strobes/vhf/pa and it was also the same reading, probably because its hooked directly to the battery.
now i have to try and also track down the squeal. gotta love a project. [img]images/graemlins/beach.gif[/img]
post #6 of (permalink) Old 04-29-2003, 09:16 PM
BigOrangeBronco
14.8 is a tad high, but not dangerously out of range. Your voltage regulator could be faulty. You don't have to pull apart the entire alternator to change it. It comes out the back of the case with a couple of screws. Still, if it is going bad, the rest of the alternator probably isn't far behind. Auto part stores sell rebuild kits which include new regulator, rectifier, brushes, bearings, etc. for $50 or less. They are not hard to do. Mine took less than an hour with no special tools. Beats a couple hundred for a new/rebuilt alternator.
