rear-end hops when first moving. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-01-2003, 02:16 PM
Its not a big prob. But I want to ask to make sure it wont cause bigger probs later on down the road. I have a 5 speed and when ever I take off in first gear, no matter how slow or low of RPM's I give it it hops for a few seconds when I let off the clutch. [img]images/graemlins/bs.gif[/img] I was wondering if yall could give me your thoughts on why it might be doing this. I just replaced the fly-wheel clutch and slave cylinder about a year ago. Another thing, when I put it in 4 wheel drive it dosen't hop no matter how hard I try to make it. Could it be my drive shaft is at too much of an angle or what? Any suggestions would help a lot.
post #2 of (permalink) Old 02-01-2003, 07:55 PM
Re: rear-end hops when first moving.
heres my theory, when you start off the axle twist a little clockwise changing the rear u joints angle so it creates a pulsation in the drive line then once you overcome the initial friction it takes less force to move so the axle doesnt twist clockwise.
McDerry is offline
post #3 of (permalink) Old 02-01-2003, 11:01 PM
rustyolred27
sounds like a typical case of axle-wrap. this is indeed woesened by lifting a vehicle such as yours.
post #4 of (permalink) Old 02-01-2003, 11:03 PM
That really sucks, what do you think can fix the problem? Will I need to extend my drive shaft or what? Is there a way to stop my rear axle from twisting like that? [img]images/graemlins/givemebeer.gif[/img]
post #5 of (permalink) Old 02-01-2003, 11:06 PM
When you lifted it, did you use a block, addaleaf, or replacement springs? A block of that size would definitely cause axle wrap.
reptillikus is offline
post #6 of (permalink) Old 02-01-2003, 11:13 PM
Yeah I used all block....I have been thinkin about changin it out to leaf though....would that fix the pro you think?
post #7 of (permalink) Old 02-01-2003, 11:39 PM
absolutely. using a block that size is like asking for broken ujoints. Change it, and when you do, check all your ujoints in the driveshaft to see if theyre still good or not
post #8 of (permalink) Old 02-01-2003, 11:40 PM
You can bet if you put springs in and torque to specs then recheck, you should have no wrap-up. Who had that pics of the rear axle that was cracked at the third member I can't find it, that's something you dont want... I was thinking it could also be tranny mount too. [img]images/graemlins/givemebeer.gif[/img]-Bob
slickerthanyou is offline
post #9 of (permalink) Old 02-01-2003, 11:53 PM
Thanks for the advice fellas, I was thinkin about changin to all leaf springs and after hearing what you guys have to say I am deff going to do it as soon as possible.
post #10 of (permalink) Old 02-03-2003, 11:41 AM
rustyolred27
new springs will definitely solve your problem. lucky for you you havent broken any u-joints with axle lift blocks of that size.
