Vibration from my driveshaft?????? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-26-2003, 03:22 AM Thread Starter
Hey whats up guys.
I'm getting some vibration from somewhere between my T-case and rear axle.
It only vibrates when i'm driving around 50MPH and ONLY when i let off the gas pedal.And as soon as i ht the gas again the vibration stops. Maybe a U-joint?????
I did it a couple of times today while i was on the highway,and when it vibrated i held on to the T-case shifter and it felt pretty bad.
Maybe i should get my driveshaft balanced.
I went underneath to see if anything was loose...all tight.
Any ideas?
Jerry D:
DVLDOG458 is offline
post #2 of (permalink) Old 01-26-2003, 09:42 AM
rustyolred27
Re: Vibration from my driveshaft??????
most likely u-joint or driveshaft out of balance.......one thing to check that has happened to me make sure that the d-shaft u-bolts or straps are tight, as this will cause one heck of a vibe and worse if it goes on long enuff
post #3 of (permalink) Old 01-26-2003, 12:09 PM
froggy
I'd almost certainly say u joint. Happens often. Have one handy in your truck just in case it breaks when your driving.
post #4 of (permalink) Old 01-26-2003, 02:28 PM Thread Starter
Thanks for the info guys.
I'm gonna replace the U-joints and we'll go from there.
post #5 of (permalink) Old 01-26-2003, 09:11 PM
Yeah, i had a wicked vibe coming from my rear, and it turned out to be a bad double cardan coupled with failing ujoints. What a difference it made changing them!
reptillikus is offline
post #6 of (permalink) Old 01-30-2003, 03:20 AM Thread Starter
Update:
I had my driveshaft balanced today and sure enough it was off and out of round.
I put in 2 new U-joints....one was shot.
I'm also replacing the tailshaft bushing,seal,and bearing from the transfer case.
I also cracked the plastic speedo gear that rides on the t-case output shaft....so i have to wait until that comes in at Ford on friday
I'll let u know how it rides
post #7 of (permalink) Old 01-30-2003, 08:02 AM
86convert4wd's Avatar
Hope fully it'll ride nice cuz your truck sure is dang purty.
86convert4wd is offline
post #8 of (permalink) Old 02-05-2003, 07:17 AM Thread Starter
UPDATE:
The Ford dealership finally got my part (speedo gear) so in she went....
Most of the vibration is gone.......but i think it's time for a custom crossmember.(thats the only thing left)
I might as well,i'm gonna go with a bigger lift this summer.And that is one piece that will have to be modified.
Thanks for all the help.
Jerry D
post #9 of (permalink) Old 02-05-2003, 07:35 AM
What are u doing with the old stuff. I have a few friends with fords and they might be interested in your springs. Lemme know
Thanks
post #10 of (permalink) Old 02-05-2003, 02:44 PM
muddybronco's Avatar
HOW MUCH more lift? your truck is already ginormous [img]images/graemlins/grin.gif[/img]
muddybronco is offline
