Washer Fluid stopped workin - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-26-2003, 12:05 AM
This is nothin big just kinda annoying. My washer fluid isn't working anymore, im guessing it must be the washer fluid motor but Im not sure. Does anyone know where the washer motor is located on a 92 f-150 with a 302. And how hard and exspensive is it to replace. Could it be something other than the washer motor?. The hose to the resivore is still connected and not leaking, and its full of fluid. [img]images/graemlins/givemebeer.gif[/img]
post #2 of (permalink) Old 01-26-2003, 12:17 AM
rustyolred27
Re: Washer Fluid stopped workin
sounds kinda like my prob. i can hear my washer motor working, just nothing comes out. the hose int the reservoir is connected and the reservoir has fluid in it. it just wont squirt. what gives? plugged hose? or just old(1981) [img]images/graemlins/bs.gif[/img] [img]images/graemlins/cussing.gif[/img]?
post #3 of (permalink) Old 01-26-2003, 12:51 PM
On an 86 the fluid pump is located in the bottom of the plastic fluid container
Can't say on a 92, but it's probably the same on an 81. I went to the "recyclers" and paid $5.00 Canadian for the whole container and just bolted her in, it worked great.
Sixlitre [img]images/graemlins/burnout.gif[/img]
Sixlitre is offline
post #4 of (permalink) Old 01-26-2003, 12:57 PM
Like RustyOl was mentioning, do you hear your motor working? Again, if you are in cold weather, I have experienced this before. I have good, -20 fluid in there, but still somewhere along the line it will freeze up on me. As soon as the weather warms some I will try it for a minute and no problem.
TheJuice is offline
post #5 of (permalink) Old 01-26-2003, 01:22 PM
BRONCOMANIA's Avatar
Wax can also dry up in the nozzle holes and plug them up, if you recently had waxed it, check for stoppage there. They can be cleaned out with a very small wire or needle.
BRONCOMANIA is offline
post #6 of (permalink) Old 01-26-2003, 01:46 PM
i had same problem in the beginning of this winter.pump and window wash were frozen i knew the pump was good so i added some rainx wash and by the next day it was working [img]images/graemlins/AR15firing.gif[/img]
93bronco is offline
post #7 of (permalink) Old 01-27-2003, 09:09 PM
Update,
well I took a look at the motor and the connections. They connections looked kinda ditry so i cleaned them up. Plugged it back together and what do you know.....works like new again. Thanks for all the good advice [img]images/graemlins/burnout.gif[/img]
