HELP!!! FOR MY 1987 Bronco - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-14-2003, 10:38 PM
I ran out of gas in my 1987 Ford Bronco[I think]So I put gas in it and still would not start. I pumped the gas peddle it smelled like gas so I left it sit for a couple hours.When I returned I called a tow truck but before he could tow it I tried to start it and it started right up,but while talking to the driver my Bronco died again I thought I ran out of gas again.So hook up to tow truck & towed to gas station put $10.00 in tank still nothing!I have fuel injectors do I need to prime them & were are they located? PLEASE HELP ME [img]images/graemlins/confused.gif[/img]WLDROSE [img]images/graemlins/confused.gif[/img]
post #2 of (permalink) Old 01-14-2003, 11:11 PM
zakt's Avatar
Re: HELP!!! FOR MY 1987 Bronco
hows the fuel pump? Is it leaking or see anything around the leak hole... or could be broke inside (had that on one [img]images/graemlins/smile.gif[/img]
zakt is offline
post #3 of (permalink) Old 01-14-2003, 11:11 PM
Fuel Pump
msuforeman is offline
post #4 of (permalink) Old 01-14-2003, 11:18 PM
muddybronco's Avatar
if you smell gas and it isnt running, it sounds more like youre not getting spark... bad coil maybe?
muddybronco is offline
post #5 of (permalink) Old 01-15-2003, 01:13 AM
Thank You Somebody else sugg. that also. [img]images/graemlins/smile.gif[/img]
post #6 of (permalink) Old 01-15-2003, 01:15 AM
Im not sure how fuel pump is?Would it just stop while running if its the problem?
post #7 of (permalink) Old 01-15-2003, 07:19 AM
86convert4wd's Avatar
Ignition module maybe?
86convert4wd is offline
post #8 of (permalink) Old 01-15-2003, 07:50 AM
When my fuel pump went out, of course I pulled over on the side. I tried it a few times and nothing. I called a friend and after about 15 minutes of waiting it cranked right up and I drove it about 1 mile than it died again. After that it was all over and I could no longer here the fuel pump priming when I would turn the ignition on. To me it sounds pretty much like what you experienced.
Good Luck,
Brian
post #9 of (permalink) Old 01-15-2003, 09:42 PM
Steve83's Avatar
Gasoline injectors don't have to be bled - that's only for mechanical diesels. Always start by pulling the codes, but my prime suspects are the coil, the fuel pump, and the ignition module.
Steve83 is offline
