ttb bushing replacement - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-11-2003, 02:12 PM Thread Starter
hey guys
i need to replace my ttb bushings could i just remove the bolt that bolts through traction beam to replace bushings? [img]images/graemlins/cussing.gif[/img]
93bronco is offline
post #2 of (permalink) Old 01-11-2003, 06:32 PM
BRONCOMANIA's Avatar
Re: ttb bushing replacement
I assume you are referring to the axle pivot bushings on the TTB axle ends and not the Radius ones, they are pressed in there really good, i think Steve83 said the easiest way he had found was to drill a bunch of holes in the rubber around the bolt hole once you get the bolts out and axle bushings supported and accessable, then beat out the remaining rubber and outer steel shell with a big hammer and suitable driver tool. Of course you could burn them out with a torch, but i really dont care for the smoke from burning greasy rubber [img]images/graemlins/bs.gif[/img]. Mine are still OK in my 86 so i have yet needed to perform this (as i had heard) wonderful repair [img]images/graemlins/puke.gif[/img]
BRONCOMANIA is offline
post #3 of (permalink) Old 01-11-2003, 08:03 PM
Shilo
Click:
http://bigb.mybigbronco.com/pivot.html
My .02 is this: get the poly replacements. IIRC they do not come with a new metal outer sleeve. This is good 'cause you can drill the old bushing out but leave the existing metal sleeve in place (MAJOR PITA to remove), then just pop in the new poly's and you're done.
'Course the even better solution is to ditch your TTB altogether LOL!
post #4 of (permalink) Old 01-12-2003, 10:59 AM Thread Starter
shilo
once i have truck up on stands & remove wheels i will be able to support ttb with jack remove bolt then lower ttb and drill out old bushing.is the steel collar molded on the piece of bushing that i drill out or is that steel collar on the outside of bushing? [img]images/graemlins/cussing.gif[/img]
i ordered energy bushing's instead of the ford oem bushing energy was $7.00 more figured these would be better since i'm putting 4 inch lift on this spring and dont want to be replacing these anytime soon.
93bronco is offline
post #5 of (permalink) Old 01-12-2003, 11:43 PM
Shilo
The only time I replaced mine the TTB was totally out from under the truck for a lift install (I shoulda just left it out from under the truck right then and there!), so I can't help you with the procedure exactly.
The metal sleeve is on the O.D. of the bushing. It will want to stay in the arm, you won't be accidentally removing it, trust me! So, drill out the rubber and press in new poly bushing.
post #6 of (permalink) Old 01-12-2003, 11:48 PM
I hit mine with sledge, popped right out, did crimp the flanged ends of the old ones first though. [img]images/graemlins/cussing.gif[/img]
This was my first time with TTB- hated it [img]images/graemlins/AR15firing.gif[/img].
I just used stock new ones, I figured if 12 years they lasted I'll go for another 12 or so! [img]images/graemlins/grin.gif[/img]
slickerthanyou is offline
