shock question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-08-2003, 11:22 PM Thread Starter
shock question
Ok here goes I have the quad shock front end and am wondering if it will hurt anything to run with just 2 up front insted of the 4 shocks upfront and what advantages /disadvantages there may be thanks
80BRONCO is offline
post #2 of (permalink) Old 01-09-2003, 06:00 AM
Re: shock question
It will work fine, but the front end won't have as much damponing as it had before when you ran 4 shocks and may not hnadle the exact same. its not that big of problem since alot of the broncos and trucks only had 2 shocks up front from the factory.
BurnedBronco is offline
post #3 of (permalink) Old 01-09-2003, 12:16 PM
froggy
Re: shock question
hey burned , was there certain years they only offered single shocks up front. Or is dual shocks for trucks with the towing package only?
post #4 of (permalink) Old 01-09-2003, 12:28 PM
Re: shock question
It was a stand alone option that didn't have anything to do with a HD suspension or towing package.
MY2ND78 is offline
post #5 of (permalink) Old 01-09-2003, 01:38 PM
Pooh-Bah
WD40's Avatar
Re: shock question
<font color="blue">TheJuice</font color> has been doing some experimenting.
Here's his latest write-up.
WD40 is offline
post #6 of (permalink) Old 01-09-2003, 07:09 PM Thread Starter
Re: shock question
Well Juice how did the out come of the test come out and do I need to let [email protected] know that I am just going to run the front or back shock of my quad set up(depends on how juices experiment came out on wheel travel) looking to save a little money and maybe soften the ride up a little since these shock are supposed to be alittle stiff
80BRONCO is offline
post #7 of (permalink) Old 01-09-2003, 07:20 PM
Re: shock question
If you have the quads stock, well, you are in luck. I run just a pair up front, not where they normally would be on the radius arms because those are not as long/limit the travel. the two pair toward the front are what I run.
Now, here is the deal, will say this just once...
BUY RANCHO 9000's period.
If you want to do your towing and also want a good trail vehicle, this is where the $$$ should go.
You will not be diappointed, and I saw in a post you are towing 5K, that's a bit...you have all the extra cooling, auto tranny, 351, proper gearing, right?
If so your rear hitch, dual add a leafs, and GOOD shocks will do the job. BUT, if you have a 3" body lift, are you leaving that?
TheJuice is offline
post #8 of (permalink) Old 01-09-2003, 07:24 PM Thread Starter
Re: shock question
I have the manual tranny (t-18)going to put in 4.11 gears (due to the 1 to 1 manual tranny ratio)unfortuntly I have the 302 nut I plan on buying a short block next winter putting in a edelbrock performer cam and heads and then putting on the howell tbi kit and hopefully it will be enough to keep me happy. and yes I still have the 3in body lift on
80BRONCO is offline
post #9 of (permalink) Old 01-10-2003, 11:00 AM
Re: shock question
Howell is more PC here than saying Chevy TBI. lol It's OK. I plan on doing mine this next summer. [img]images/graemlins/grin.gif[/img]
BigNorm is offline
post #10 of (permalink) Old 01-10-2003, 12:44 PM
Re: shock question
Well, here is a bit more info. for you...this is just info. I am not saying "can't" here:
For 1996 Ford Broncos, the brochure shows that a Bronco equipped with 5.0/3.55 and auto can max tow (equipped with Tow package) 6600lbs. With a 5.8 that jumps to 7000 a good ton more than what you are looking to tow. However, with 5.0/manual/3.55 that figure is only 3000lbs. So, I don't know how much stronger or differently geared your older manual is compared to the new ones, but.....
maybe [img]images/graemlins/bs.gif[/img] or maybe [img]images/graemlins/cussing.gif[/img]
TheJuice is offline
