Fuel Pump Buzzing - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-29-2002, 10:25 PM
Fuel Pump Buzzing
95 Bronco XLT, 302, 120,000 miles.
Iíve got a buzzing (not the usual whine) from the in tank pump. No codes and the truck runs fine. Does this indicate pump failure or could this be something else like the pressure regulator?
Thanks,
Mike
post #2 of (permalink) Old 12-29-2002, 10:26 PM
froggy
Re: Fuel Pump Buzzing
HUH , dunno. I always thought you should here a little something back there. How loud is it and does it sound like grinding or something?
post #3 of (permalink) Old 12-30-2002, 08:54 AM
Do a search when it comes back up I know there are a ton of threads on this. I know that the electric in tank fuel pumps on the bronco seem to be a high fail item so much so that a few of the guys have gone and cut an access dr to the fuel tank in the rear bed. I would bet that it is going bad.... of course I guess depepinding on how you look at it they start going bad the day they start working [img]images/graemlins/grin.gif[/img]
80BRONCO is offline
post #4 of (permalink) Old 12-30-2002, 09:13 AM
Shilo
If you believe the sound has changed significantly then it could be wise to r&r it, but these pumps make noise regardless.
post #5 of (permalink) Old 12-30-2002, 01:12 PM
Shilo,
Thanks for the reply. A change in the noise is definitely what triggered my post. The sound went from a whine (which I think is normal) to an intermittent buzzing (bearing?). Itís been suggested that I run a pressure test to eliminate the regulator. Iím going to buy a gauge and try that. However, according to some on this and other forums this whining/buzzing isnít necessarily a problem. Iíll get back.
Thanks again,
Mike
post #6 of (permalink) Old 12-30-2002, 02:01 PM
Shilo
I'd put zero stock in a pressure test even if it comes back good (if it comes back bad something is clearly wrong). These pumps generally fatigue and will fail under high temps or heavy loads, but when cold or recovered or at idle or whatever they'll *appear* to work fine, and produce pressures within spec.
IOW, a normal pressure test does not mean your pump is not waiting to become intermittent.
All I can tell you is my Napa replacement buzzes louder than the dying OEM, but it's worked great for 3+ years, under heavy loads at high altitudes. I still carry a trail spare, tho.
post #7 of (permalink) Old 12-31-2002, 07:20 PM
Steve83's Avatar
Fuel Pump load
The pressure regulator keeps the load on the pump almost the same all the time. The only time it changes is in those moment before the regulator has time to react, which means it works less when you stomp the gas (injectors open, dropping the pressure), and more when you suddenly let off (pressure jumps).
Considering the minute amount of heat generated by the motor, the volatile nature of gasoline, and the fact that a boiling liquid will not increase its temperature, you can bet that the pump never gets significantly warmer or cooler, except for the few moments before it runs totally dry. Otherwise, it's gonna be the same temp as the gas in the tank, which is flowing thru & around it.
Steve83 is offline
