Speedo Error Correction??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-29-2002, 04:22 AM
Hey guys, I got the speedometer cable fixed and working, but apparently the coupler cable that had snapped was aftermarket with some kind of reduction for the correct speed with 33's. Now that it's back to stock my speedo reads about 8-12 mph faster than I'm going. How can I correct this? I know you can change the gear on the speed sensor, but without being able to set the gear mesh to allow for a bigger gear, the choices of gear teeth # seems limited if not fixed. Any thoughts??? Right now the gear is a 17T and I think either a 19T or a 20T would get it back pretty close. Thanks!
~Mike
post #2 of (permalink) Old 12-29-2002, 02:43 PM
Steve83's Avatar
Re: Speedo Error Correction???
Don't worry about setting the mesh on those little plastic gears! [img]images/graemlins/wink.gif[/img] [img]images/graemlins/grin.gif[/img] Ford designed them to work together in any combination so the factory guys wouldn't have to worry about it, either. [img]images/graemlins/smile.gif[/img] Just calculate your correction and stick the closest ratio gear in.
Yeah, just stick it in! [img]images/graemlins/smirk.gif[/img]
Steve83 is offline
post #3 of (permalink) Old 12-29-2002, 04:00 PM
When I called about the gear teeth the ford parts prople said for every tooth equaled 3 mph [img]images/graemlins/givemebeer.gif[/img]
80BRONCO is offline
post #4 of (permalink) Old 12-31-2002, 08:09 AM
Steve83's Avatar
You can't accurately express a speedo correction in mph, because at 0mph, it doesn't change it at all. You have to say 3mph change AT a given speed, like maybe 60mph. But then you're saying xmph/ymph, which is just a ratio (x/y), which is how it actually affects the speedo reading. It's a percentage change or just a pure ratio. And an increase of 1 tooth over 18teeth isn't the same change as 1 tooth more than 19t or 20t, so even if it was exactly [email protected], it wouldn't be exactly the same change for every size gear.
I'm being really technical, but when you're setting your speedo, there's no point if you're not gonna be precise.
Steve83 is offline
