Overheating......But its not??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-13-2002, 10:11 AM Thread Starter
86convert4wd's Avatar
When ever i shut the truck off for more than a minute the gauge creeps all the way up past hot. As soon as i start the truck it creeps back down between the R and the M in Normal which is where it stays for pretty much the whole time i drive it. In the summer when i'm really hard on it it may creep up to half of the M but that's it.
I have plenty of coolant and the thermostat is new along with the radiator. I never had this problem with the 89 which had this motor in it with the same thermostat. The radaiotor was put in about 6 month before i bought the truck. The water pump was replaced with a new Ford unit along with the fron cover. The Serp belt is new along with the tensioner. I have half of a fan shroud because of the body lift. The fan clutch was replaced about 1 year ago with a used but good one. All hoses were replaced with OEM hoses and the heat works fine(aside from a leaking heater core, but i'll fix that this weekend when i get paid). The rad cap is new and swapping it with one of the many spares i have does nothing.
Is this a cause for concern? I figure it's caused by the body lift cause i had no problem with the other truck. Anyone else with the same problem? The guy i bought the truck from is no help casue he hated it so he just ignored the squeeks/creaks/clunks/grinding/problems that it had. That's why i swapped everything over with the stuff i couldn't kill in a year of hard driving.
86convert4wd is offline
post #2 of (permalink) Old 12-13-2002, 11:12 AM
Re: Overheating......But its not???
Thats the fan clucht boy!, i had the same problem, try to rotate the fan whit your hands and you will see, it most be about to break down, buy a hevy duty, that will be a 15 min solution...
agin2000 is offline
post #3 of (permalink) Old 12-13-2002, 11:29 AM
Shilo
Your gauge should not provide a reading when the truck is off. I mean it might sit somewhere but that doesn't mean it's reading.
But it's possible Ford wired it such that it's hot all the time (not good for long term storage of the vehicle as it could drain your batt). If so, I think this still sounds normal. I'll tell you on any vehicle temps will spike once it's shut off.
I put a REAL mechanical gauge on my van and it'll idle/run at 190 all day long, but once I turn it off the temp climbs to 215.
post #4 of (permalink) Old 12-13-2002, 11:39 AM Thread Starter
It provides the reading when i cycle the key back to the on position before i start it. Like when i get gas i cycle the key back to on after i shut if off to watch the gas gauge move so i have an idea of how much $$ to grab. We have full service in Jersey so legally you're not even allowed to touch the pump at all.
When the truck is off all the gauges fall to 0/low/cold/empty.
How would the fan clutch cause this problem? It cools no problem. Maybe the heat that build up after the WP stops movin? It's been doin since i put the motor in the truck with a body lift so i though that might be part of the problem.
post #5 of (permalink) Old 12-13-2002, 12:34 PM
I had the same problem with my '86. And believe it or not, it was caused by plugged CAT. The excess fuel needed to accelerate through the Cat was heating up the bottom half of the motor. It used to go so far as to empty itself when you shut off the key. New low restriction Cat solved the problem.
Just a thought...
XTweety is offline
post #6 of (permalink) Old 12-13-2002, 12:43 PM
vitaminc
Heat soak
Increasing coolant temperature after engine shutdown is normal. Once the water pump stops circulating coolant, the engine block continues to transfer heat to the coolant (and the outside air) which raises coolant temp. Usually continues for about 10 minutes or so.
Like you've observed, once the engine is started again, the circulating coolant cools quickly.
post #7 of (permalink) Old 12-14-2002, 06:45 AM Thread Starter
Re: Heat soak
That's what i figured it was. Just figured i'd ask around to see if i was crazy and make sure it ain't a big deal.
