pulled codes, fixed the problem? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-23-2002, 05:41 PM Thread Starter
I pulled codes and this is what I got, 32 32 sep 10 41 32 41 nego. Then I replaced my spark plugs with Champian truck plugs, changed o2 sensor, and cleaned egr valve and replaced the gasket, then I cleared all of the codes. Now my check engine light is flashing on and off! Is there any thing else wrong, and what does it mean when the check engine light flashes?
bucknbronc is offline
post #2 of (permalink) Old 11-23-2002, 05:59 PM
muddybronco's Avatar
Re: pulled codes, fixed the problem?
sounds like you're still in code-checking mode, unless it's flashing with a regular beat? that would be a first!
muddybronco is offline
post #3 of (permalink) Old 11-24-2002, 03:32 PM Thread Starter
Anything else I should know?
post #4 of (permalink) Old 11-24-2002, 03:36 PM
well, is it flashing at a steady rate or does it pause sometimes?
post #5 of (permalink) Old 11-24-2002, 04:46 PM Thread Starter
It will flash at a steady rate for about 5 seconds then turn off, then will turn back on again every once in a while.
post #6 of (permalink) Old 11-24-2002, 07:14 PM
yep, sounds like you're stuck in code mode... is your harness still jumpered somehow?
post #7 of (permalink) Old 11-24-2002, 07:29 PM Thread Starter
I'll check it, but I probably need to replace the fuel pressure regulater, because it's still runnin' rich!
post #8 of (permalink) Old 11-25-2002, 09:07 AM Thread Starter
Now all I need to know is where the fuel pressure regulater is located!?
post #9 of (permalink) Old 11-25-2002, 01:00 PM
It's on the back left(driver) side of the fuel rail.
I agree with Muddy, you probably left the self test connector connected for the flashing engine light.
After your sensor repairs make sure you clear the old codes, too.
