Ignition switch? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-05-2002, 05:23 PM Thread Starter
Ignition switch?
When I remove my key from the ignition and have my drivers door open I get that dingging sound, It's the same sound as if you left your keys in there with the motor off and open the door. Also when I try to put it in the Accessories position it used to click and that's gone too. Is this a hard thing to do? I couldn't find it in the haynes bible. How do you get the switch out of the colum? I had the recall done about a year and a half ago. Is this not the part they replaced?
slickerthanyou is offline
post #2 of (permalink) Old 08-05-2002, 08:16 PM
Re: Ignition switch?
The recall was for the ignition switch down under the column.Not the key switch.I thought the haynes had a procedure for changing the key switch.I did mine a while back seems like you had to turn it to a certain key position and take a small punch or drill bit and stick it through a hole in the column to release the switch and pull it put.
Billy
broncobilly69 is offline
post #3 of (permalink) Old 08-05-2002, 11:00 PM
Steve83's Avatar
The ignition switch is the electrical device mounted to the side of the column under the instrument cluster. The lock cylinder is what the key goes into. The operating rod connects them, but tilt columns have about 3 sections to the op rod, and 2 of them are cast pot metal that commonly bend &/or break.
To remove the lock cylinder on a tilt column, put the key in the Run position and use a small punch or rod to depress the pin in the hole on the bottom of the steering column near the lock cylinder. ('92-97 - the hole is smaller than the screw holes for the plastic column shroud.) On '7?-91 non-tilt columns, the hole is INSIDE the column, and requires the steering wheel to be removed before the pin can be depressed. On all columns, to install the cylinder, make sure it's in the Run position, insert it, and turn the key to ANY other position.
If the switch doesn't respond correctly to ANY key position, the op rod is probably broken. It's a HUGE pain to replace it on a tilt column, but a piece of cake on non-tilts.
If the switch responds correctly to only SOME of the key positions, the ignition switch is probably damaged, and they're pretty easy to replace. If it's held on by tamper Torx screws, use a small punch to break the center post out and use a normal Torx bit to remove them.
Steve83 is offline
post #4 of (permalink) Old 08-06-2002, 06:04 PM Thread Starter
Ok. Looks like it's time to get a new lock cylinder- Ya I have tilt so I hope it's not that rod. Seems pretty easy-thanks-Bob
post #5 of (permalink) Old 08-11-2002, 11:05 AM Thread Starter
Well It was the lock cylinder. No more annoying dinging noise Waahoooooo! Thanks for the help!
