fuel filter connectors...what are these things? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-02-2000, 11:21 PM Thread Starter
muddybronco's Avatar
I'm trying to change out my fuel filter on my 93 and can't tell how the connectors work. The fuel return line has a similar connection but has a clip on it, mine just has two bellshaped things that look like they'd slide off, but didn't when I tried. I looked in the haynes manual and it doesn't look like the 3 types in there...what's up?
muddybronco is offline
post #2 of (permalink) Old 05-03-2000, 02:02 AM
Re: fuel filter connectors...what are these things?
I'm no big knower of Fords, but from my experience most of their fuel connections require a special tool that clamps over the line and when pushed into the fitting, releases the connection. I think they come in three different sizes. You should be able to get them at your local auto store. However, I've never worked on anything as new as '93(only '80s), but they probably are the same.
Good luck PJL
post #3 of (permalink) Old 05-03-2000, 02:53 AM
My guess is that your fuel filter isn't any different than the one on my '91 SAE Bronco, and if that is so - you buy a new fuel filter and there will be directions on how to replace your old one.
Which consist of prying the old horseshoe clips out with a screw driver. Takes about 3 minutes to change out the fuel filter. But remember to releave your fuel pressure, or you will get misted with fuel when you go to disconnect the old filter.
Technoman
'91 5.0 SAE Bronco
post #4 of (permalink) Old 05-05-2000, 08:06 AM
If the 93 is like the 94, using the Motorcraft FG-872 filter, then the connectors are "Push Connect" type. They have a metal safety clip, that you pull back part way. But sometimes people take the clips off all the way, and don't put them back on. The fitting requires a simple tool to release, as mentioned above, like the KD 3321 Quick Disconnect tool. Its metal, sort of like a scissors with pipe-like pieces on each end. Close it around the filter tube, then push it into the fitting to release the internal locking fingers, then pull on hose while pushing more on the tool. Should come off easy. Don't bother with the little plastic slip-on ring type tools, they won't fit in next to the filter. If instead it uses the FG-800A style filter, like used on lots of older Fords, then no tool is needed, just follow the directions that Technoman said.
