Laying Rubber
Does anybody else's Bronco do this?
94 FS Bronco, front end is tight, wheel alignment must be OK, as tire wear is flat across, no pull or anything unusual.
Tires are the stock XLT size 265 75R15, as per the door sticker.
When backing up in a TIGHT turn on concrete pavement (in 2WD, and hubs are unlocked), the INSIDE edge of the front tire on the OUTSIDE of the turn, leaves a black rubber tire mark. Can see the edge of the mark clearly on the pavement, and the mark fades out across the tire width.
So, for example, if backing up with the wheel turned hard LEFT, the inside edge of the RIGHT front tire leaves a mark. And vice-versa, if backing while turning hard the other way.
Its always done this while I've had it, just didn't back up in that tight of a turn much before.
