Heater Core Replacement - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-30-2000, 02:36 PM
I have a 1987 Bronco with a carbed 351W.
I have been having problems with my heater core for a while. Now it looks like its a cross between a humidifier and a sprinkler sitting behind my dash. Anyway, I'm gonna replace it next Sunday and was just wondering if you guys had any tips for me as for how to remove and replace it. So far, all I have done is removed the door to the glove box (I don't need to remove the entire dash do I?), and removed the cover to the Heater Core. I have no idea what to expect for the rest of the project, so any tips will be of great service. I imagine that there would only be a line going into it, and a line going out of it, and a few screws holding the whole thing in place. When I disconect the lines, will there be antifreez pouring out all over the place?
Thanks for your time.
Tom
post #2 of (permalink) Old 04-30-2000, 04:25 PM
Re: Heater Core Replacement
Hey, My heater core is leaking pretty bad too. Someone on a bronco list told me that since its summer, you can get away with bypassing the heater core and fixing it later (unless you use the heater in the summer). I havent gotten a chance to look into doing this, but I might later if I'm too cheap to fix it.
Roland
post #3 of (permalink) Old 04-30-2000, 05:45 PM
Its not that hard to replace, and from my experience, I would replace it now because for some strange reason prices on heater cores go up in the winter(For the same reason I had to pay $60 more for an A/C compressor in the summer then the winter!). When you disconnect the hoses anitfreeze will come out. Put a tarp or something in. The chiltons manual explaines the proccess fairly well.
good luck
post #4 of (permalink) Old 04-30-2000, 09:25 PM
Here is what you do.
What you have to do is remove the glove box door at the bottom hinge and remove the glove box itself. There are only four screws for that. This allows you to get to the upper two screws that hold on the heater core cover. The lower screws can be easily reached and are in plain sight. The cover will pop off and you will see the core. The hardest part is getting the old hoses off the inlet and outlet pipes under the hood. I suggest you take this time to replace the clamps and heater hoses. The dash does not need to be removed.
Good luck, Eric.
If it ain't broke, I can probably still fix it.
post #5 of (permalink) Old 04-30-2000, 09:49 PM
Re: Here is what you do.
Thanks for the tips. I wasnt expecting to go under the hood, I thought it was all done from the inside, but then again, I'm clueless. By the way, I've been breathing these damn fumes for a while now. At times it would almost fill up the truck with smoke. I can't imagine that antifreeze fumes could be good for you.
