back window won't go back up...where is tailgate closed sensor? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-30-2000, 12:50 AM Thread Starter
muddybronco's Avatar
back window won\'t go back up...where is tailgate closed sensor?
I've heard all broncos eventually have this problem, but I think mine might not be with the motor, but with the sensor that says the tailgate is closed because i can hear the motor try to roll it down when i push the down button, but makes no noise at all when i push the up button. Where is this sensor?
muddybronco is offline
post #2 of (permalink) Old 04-30-2000, 01:50 AM
Re: back window won\'t go back up...where is tailgate closed sensor?
its on the inside of the tailgate mounted on the key switch
post #3 of (permalink) Old 04-30-2000, 03:03 PM
It could be the sensor or it could be the switch in the dash. I've had problems with both.
If the window works the same from the dash as from the rear using the key it's probably the sensor. If it works OK using the key, it's probably the dash switch.You can try to clean the switch (I broke my trying) or replace it (what I ended up doing).
If you decide it's the window sensor, Pull the rear cover. On my 88 the switch is in the center by the tailgate handle. It can be adjusted or bypassed.
When you have the rear cover off, its a great time to clean and lube the mechanism.
- Dan
99 4Runner (wifes grocery getter)
88 Bronco * FOR SALE *
Looking for a new trail rig...
post #4 of (permalink) Old 05-01-2000, 08:40 PM Thread Starter
thanks for the help...i used my stereo wiring as a power source and after i rolled it up i just shorted the connector to the latch switch...works fine now.
post #5 of (permalink) Old 05-02-2000, 02:57 PM Thread Starter
or so i thought it was fixed...won't go up again. can't be the motor because another power supply works, and can't be the latch switch because it's bypassed. must be a loose wire, but i wonder where it is. i might just run new wiring and a new switch straight to the motor connector if i can't figure it out. i'll let you guys know if i figure it out.
post #6 of (permalink) Old 05-03-2000, 01:12 AM
Sounds like mine when the dash switch was going bad.
