Ford 9" or Corp. 12 bolt-which is stronger? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-30-1999, 06:36 PM
Ford 9\" or Corp. 12 bolt-which is stronger?
I realize you guys might be a little biased, but please try and support your answer[img]/wwwthreads_images/icons/wink.gif[/img]. I am getting ready to swap either a Ford 9" rear axle into my truck or a Corp. 12 bolt. The use of the truck will be for extreme rockcrawling. I will equip either axle with a full floater kit and a detroit locker as well as alloy axle shafts. My question about strength relates to the housings, ring and pinion gears(and bearing caps, etc.) as well as the axle shafts themselves. Thanks for any input.
Sean
post #2 of (permalink) Old 12-30-1999, 07:54 PM
Not sure, but here are the pluses for the 9\"
I know a lot of drag racers run the ford 9". There has to be a reason! A LOT of heavy duty parts are available for it, and it is easy to swap gears in. Lockers and limited slips are plentifull also. It can be narrowed easily because of NON-tapered axleshafts In case your putting it in a Jeep, early Bronco or BroncoII I think the houshing is small compared to most, so it may provide better ground clearance. I'm not very familiar with the 12 bolt, but I think my dads truck has one, and the housing sits really low. Is the pinion raised above the centerline of the axles on it? I can't remember. Anyway, What kind of Truck are you putting it in? you may have to fabricate axle and shock mounts too. Just my input, maybe someone else will know more about the 12 bolt.
post #3 of (permalink) Old 12-31-1999, 03:08 PM
Re: Not sure, but here are the pluses for the 9\"
Thanks for the input Dave. I'm either going with the Ford 9" or the Dana 60. Thanks again,
Sean
