still no run:( - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-08-2002, 10:48 AM
still no run:(
ok, afer that long post last week trying to figure out what was wrong, i gave up on fuel injection. took off the injection, and installed the carb now. i have 7 psi of fuel pressure to the carb, a crane 900 ignition module, putting off a great spart out of a msd blaster 2 while cranking the engine, 150 psi of dry compression on every cylinder after 3 revolutions, and i have moved the distributor aimlessly to no result. this leads me to believe that whatever is wwrong must be internal to the engine. now i have built many an engine, and never had such a problem. my gut tells me, the cam is broken, but in my experience, if the cam had broken off, i would not build compression on every cylinder. anyone have any thoughts or comments or suggestions? i really dont want to pull this engine again. only put it in bad in october/november.
Dpminic
"MUD BUCKET" 1984 bronco, 88 302, 32x11.5 , I am at screen name iskybantilus on instant messenger.
post #2 of (permalink) Old 01-08-2002, 02:20 PM
Re: still no run:(
You rebuilt the engine? If so, are you sure you have the distibutor in right? (Not 180 deg out?). Is the rotor spinning when you try cranking it? If not, timing chain may be off.
post #3 of (permalink) Old 01-08-2002, 02:34 PM
Re: still no run:(
well, found out the problem. good thoughts ron-bo, but my engines are good, and i already checked all that. the problem was gas fouled spark plugs. i kinda thought one or two might be bad, but it shuld tried to run on 4-6 cylinders. now onto a new problem. steve, you mighta washed out a carburated engine and converted to fuel injection, but aparently i washed out a fuel injected engine, and am going carburated. the oil in there still has gas in it, but it sure sounds like a rod knock to me. gonna go get some 15-40 and change her up, but looks like this 2000 mile motor might be coming out.
Dominic
