Just the battery going... or other problems? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-02-2002, 12:36 PM
Hey folks,
The electrical stuff in the '83 has been acting up recently... real weird stuff like no turn signals but hazards, no radio, no heat blower, but headlights, and I can roll down the back window, no brights accessory lamp. Nothing real consistent either. The other day it wouldn't turn over at all, got a jump and started up fine. I'm going to replace the battery this week, but I'm wondering if its just the battery or if something else is shot... is there a way to test the alternator to see if it's charging? I've heard disconnect the battery when the truck is running... Any other suggestions? Its a carbed 300.
Thanks,
Ryan
post #2 of (permalink) Old 01-02-2002, 01:33 PM
Steve83's Avatar
Re: Just the battery going... or other problems?
That's generally a bad idea (especially on EFI's) - a better way is to simply check the voltage with the engine running. It should be between 13.5-15.5V if the alternator is working and the battery isn't totally dead. But the wierd array of non-functioning circuits suggests blown fuses or fusible links (the wires near the battery). Check a Haynes manual and see if the affected circuits share a fuse or fusible link and then check all of them. To check a fusible link (once you FIND it), gently pull from the ends - if the rubber stretches, the wire inside is burnt.
[email protected]
Steve83 is offline
post #3 of (permalink) Old 01-02-2002, 02:47 PM
Shilo
Voltage regulator is another possibility.
post #4 of (permalink) Old 01-04-2002, 03:09 PM
Today's update... just got the battery checked at lunch and its low (but good), going to have the alternator checked tonight which brings up the question - how long do alternators last? Don't know if this is the original one, but they degrade over time as opposed to just braking, don't they?
Thanks,
Ryan
post #5 of (permalink) Old 01-04-2002, 06:03 PM
Shilo
Yeah, alts will usually get weaker and weaker until they die out completely. But anything is possible. I don't think they have anything to do w/braking, but I suppose they could break :-)
