Need Help Front Crossmember wont go back in
I have a 2000 Dodge Ram 2500 With a Cummins, I removed the skidplate and crossmember assembly the other day to replace some ujoints in my front driveline. Boy it was a pain to get that member out of there, well now I can not get it back in. The spot where it goes is tapered, with a larger protusion at the bottom of the frame, and the crossmember is like an inch to wide and the lips of it will not go inbetween the two frame rails on each side at the same time, anyone who has ever done this tips would be great, as of now I cannot even go to work because of this problem.
Mike
