Compression - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-08-2003, 07:26 PM Thread Starter
Compression
What should compression pressures be for a 79' 360, if it matters it's in a 4x4 Ramcharger?
pitviper is offline
post #2 of (permalink) Old 01-09-2003, 11:35 AM
raminaredickson
Re: Compression
I,ll tell you the same thing an old timer told me [and it pretty much holds true to this day ] here go,s- under a 100 pounds per cylinder JUNK IT - a 100 or better with run it - a 125 or better will run it down the street - a 150 or better will burn the tires off / you wont get more than that unless its a new motor / the motor must be completely warmed up with all plugs removed and the carb wide open when you check it / good luck
post #3 of (permalink) Old 01-09-2003, 04:42 PM Thread Starter
Re: Compression
I forgot to hold the throttle open when I did it so which way would that make the readings go, up or down. The highest I got was 140 and the lowest I got was 130 but it was pretty even across.
pitviper is offline
post #4 of (permalink) Old 01-12-2003, 06:13 AM
raminaredickson
Re: Compression
it wont change the readings to much but with the carb closed it draws gas into the motor and can flood it out / 130 - 140 aint to bad at all
post #5 of (permalink) Old 01-12-2003, 03:10 PM Thread Starter
Re: Compression
That's what I figured but I wasn't sure. Thanx for all the help
pitviper is offline
