Re: AIR SYSTEM
Be very carefull about what the dealer "Tells" you. It is very different that what is in writing. The Warranty states that if an aftermarket item is installed and is found (by Chrysler) to be the cause of a failure, the failed item will not be covered under warranty. ie: If Chrysler determines that the K&N air filter caused debris to enter the engine, the engine warranty is void. If, however, a Chrysler dealer installs the item AND you get record/recipt of that install, then Chrysler cant void the warranty. This isn't meant to scare you off of a K&N, they are excelent filters, it's just a loophole that allows Chrysler to get out of paying if you have a problem down the road.
