Do the t-case and auto tranny swap fluids? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-02-2002, 11:29 PM Thread Starter
AJMBLAZER's Avatar
Still saving for all the various things I'm going to do at the same time on the tranny, but meanwhile I've got this jug of ATF +4 sitting here that I could put in the transfer case. Are the tranny's and t-case's sealed off from each other, or do they swap fluids a bit?[img]images/graemlins/tongue.gif[/img]
AJMBLAZER is offline
post #2 of (permalink) Old 12-03-2002, 06:10 AM
raminaredickson
Re: Do the t-case and auto tranny swap fluids?
NO they do not swap fluids / there is a seal in the tranny to transfer case adapter / I personally run 10w motor oil in my transfer case / it has lasted 15 years of extreme wheeling after I rebiult it from bearing failure from useing tranny fluid / tranny fluid does not lube very good under hard use / under normal use its fine
post #3 of (permalink) Old 12-04-2002, 11:43 AM
The newer t-cases such as the 231 and 241 are designed to run on ATF and I would not recommend running motor oil in them. However, some older t-cases such as the NP203 were designed to run on oil such as 10W-30 I believe.
post #4 of (permalink) Old 12-13-2002, 05:50 PM
AJMBLAZER- yes, both the transfer case & the auto tranny use ATF.
ATF+4 is recommended, as it supersedes ATF+3, with the added benefit of running cooler, foaming less, providing higher wear protection, and less viscous cold weather usage.
Use that jug of ATF+4 [img]images/graemlins/laugh.gif[/img] , and since you have a 231 transfer case, leave the engine oil where it belongs-in the engine.
