diff & trans - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-02-1999, 12:17 PM
diff & trans
"84 RC with Mopar 9 1/4 diff. makes growling sound when turning left or right. Have been told that the rear wheel bearings
are failing. If this is true, is it a big deal to replace them? The recommended diff. oil for my 94 Grand Cherokee with a towing
package is synthetic 74-140. If a person were able to find this stuff, would benefit in an old truck pulling a horse trailor.
The recommended trans. oil for the '84 727 is Dextron II, but it seems its no longer available. The '94 Jeep with its
727 with overdrive, recommends ATF . Turns out Valvloine has replaced ATF with ATF 2 and later with ATF 3.
The blue plastic bottle says" ATF 3 is a quality engineered fluid designed to meet the specific requirements of Chrysler Automatic Tranmissions". Would any of you take a chance with this stuff in a truck with over 200K miles?
ATF .
post #2 of (permalink) Old 10-02-1999, 09:50 PM
Re: diff & trans
Can't help with the Cherokee stuff, but the rear axle bearings are pretty easy to swap. Not to mention the at they are pretty cheap...........However, depends how bad your bearings have gotten. My 76 had worn into the actual axle. So I had to locate and replace the axle in the process. Not a big deal, but just something to think about. As far as the rear bearing itself goes, you have to jack up and safely suport rear of vehicle, pull the rear brake drum, drain the diff fluid, pull off the dif cover, remove the spider gear cross pin (small bolt holding in). Push in on the axle and then pull the 'c' clip from the ring/pinion side of the axle. Slide axle out, use slide hammer to remove old bearing/seal, drive in new bearing and seal and put it all back together again. Put in new diff fluid. I haven't tried this with a Sure-Gripped 9 1/4, but my open rear was no problem. =)
Hope this helps
Mike (440trk)
