318 1985 Ramcharger Engine Vibration - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-22-2002, 07:15 AM
I have a probelm with my 318 85' ramcharger. It has a wicked vibration in the engine. It is definetly with the mechanics of the engine not mounts or anything. Does not matter if I am moving or parked. (Automatic trans) The vibration seems to resonate at certain RPMs (about 1/4 to 1/2 throttle), milds out above and below the RPM's. Load affects it not. I had just replaced the timing chain after the old one jumped from being wickedly stretched out. Could I have bent something. Could it be the timing or just the harmonic balancer going out. Any suggestions would be helpful. If it is most likely valve train would a rebuilt block from the auto store be a good idea?
thanks
1985 Dodge Ramcharger
318 w/Automatic Trans. (Adopted and saved from Junkyard dog status)
Some new fog lites but otherwise stock.
IH Scout II
345 727 Automatic Trans.
3.07 Gears
Stock lift but not for long
post #2 of (permalink) Old 11-23-2002, 03:02 AM
Re: 318 1985 Ramcharger Engine Vibration
Check to make sure the main bolt on your harmonic balancer is still tight. After doing a head gasket change an OHC engine I had a similar problem a couple weeks later, turned out I haddn't gotten the crank bolt tight enough and it came loose again.
Good Luck.
