92 2WD Dakota Lift - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-19-2002, 05:09 PM
92 2WD Dakota Lift
I have a 1992 2WD Dodge Dakota w/ 3.9mag. I recently got the idea in my head that I would make this truck a 1970s
prostocker by flipping the rear axle that was at one time over the leaf springs, to its new location under the leaf springs. I also added blocks to the new setup to increase the rears ride-height rougly 8.5 inches. Afterward, I got out the welder and ordered myself some chrome 64 inch sidepipes and slapped them on. The look is nice, but too much downward. Question now being: I cannot find a complete suspension lift for this truck and i was to raise all four corners up. I've heard of replacing the stock front coils with longer ones but I haven't been able to find them anywhere. Any help in this matter would be greatly appreciated. If anyone has any other ideas in lifting the front end, I'd like that as well. I'm only looking for about 3-4 inches lift in the front end. Thanks Again.
- Fox Deacon, 1992 2WD Dodge Dakota Extended Cab
post #2 of (permalink) Old 08-20-2002, 10:52 AM
AJMBLAZER's Avatar
Re: 92 2WD Dakota Lift
Since you aren't offroading it, try Fabtech.
AJMBLAZER is offline
post #3 of (permalink) Old 08-20-2002, 09:38 PM
superswamper's Avatar
Try a set of coil spacers that are the same width as yours like maybe a toyota spring, I think theres a spacer for theres but I doubt theres one for the early dakota. Maybe tuff country has one available?
superswamper is offline
post #4 of (permalink) Old 08-21-2002, 12:00 AM
If the coil spacer was 2 inches wide, would that make for a 2 inch total lift, or would there still be some sag and say a 2 inch coil spacer result in an inch lift?
post #5 of (permalink) Old 08-22-2002, 09:21 PM
It would be a full 2" of lift, some spacers are poly which don't need your factory rubber coil ring to seperate it from being steel on steel but theres also the steel or aluminum spacers that still use it. They are made to compensate for that. The daystar spacer is actually bigger than 2" but with the ring out its right...
post #6 of (permalink) Old 08-26-2002, 12:52 AM
Just wanted to close out the post by saying I went with the DayStar 2.5" coilspacers and they work/look fantastic. Before and after measurements prove that it was a complete 2.5" inch lift, as i had asked previously. Thanks Alot Everyone. Now for tires... [img]images/icons/wink.gif[/img]
