77 Dodge-1st tow run-Questions on improvement - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-16-2002, 09:38 PM Thread Starter
I just towed my rock crawler using my new 77 dodge w-200.It has 32x12.50 tires,4:10 gears,crate motor,Blue printed/balanced,
tow cam,alum. intake,carter 4bbl,headers,flow masters.It has no pulling power from 0 to 60mph.65mph on the interstate is not bad.Hit a hill,she drops to 40mph.QUESTION,Would a centrifical distributor help.The 727 torque convertor seems to drain down for 1 thing when it sits and it seemd to slam gears when it shifts to 3rd as if something is bound up.I am only towing a 3500# rig.My S-10 pulled 5000# no problem.I also want to go to P/S.I want to add P/S.What year box does it take?Any ifno appreciated,RR
rangerrick is offline
post #2 of (permalink) Old 07-17-2002, 09:29 AM
aarcuda
Re: 77 Dodge-1st tow run-Questions on improvement
you should be able to pull 5000lbs easy with that setup. You have something setup wrong. You say you dont have a centrifical advance in your distributor?? What kind of distributor is that? you need advance at rpm. timing should be set about 34 degrees (36 max) at 3000 rpm.
post #3 of (permalink) Old 07-17-2002, 03:25 PM Thread Starter
I have standard dist. now.I am going to put the truck on a dyno to set it up.Do you know what power steering pump guys out there use.I heard a 77 1/2 ton ,but want to do this right first time.Thanks for you reply,RR
post #4 of (permalink) Old 07-19-2002, 09:03 AM
How about some more info on that motor "crate motor" really don't mean a darn thing.
post #5 of (permalink) Old 07-19-2002, 04:58 PM Thread Starter
Crate 318 motor;stock compression new engine.Added goodies,alum intake,4 bbl carter/weber,RV cam unknown modle,headers,2 1/2 " exhaust,flow masters,new distributor,hipo electronics;coil,wires,plugs,ect.Thanks RR
post #6 of (permalink) Old 07-19-2002, 05:02 PM
Well a stock 318 really is no power house for pulling. And with out knowing the cam specs it is hard to say. Intake, carb, headers, ect really wont help you much if the the rest of the motor can't take advantage of it.
post #7 of (permalink) Old 07-19-2002, 09:08 PM
superswamper's Avatar
Hi mopar mudder, hows those new 39.5 boggers? Are they much better than your old sx's? I never can tell much of a difference when I switch swampers, they all pull through most stuff I send them thru...
superswamper is offline
post #8 of (permalink) Old 07-20-2002, 08:47 AM
Well to tell you the truth I only made one run in the mud with them so far when out in NE for Ram Jam and took reverse out and the front drive shaft. They worked just fine out in CA for Dodge City. So I have been to busy wokin on building new front suspension and swaping over to an automatic. Plus puting a R/C together. But next week end we have a deal coming up, will get more test time then, I can tell you they are more "interesting" on the road then the SX's were.
post #9 of (permalink) Old 07-20-2002, 10:04 PM Thread Starter
I am in great hopes the dyno will help bring in the engine torque band.I may go to 4:88s to help with the towing if the torque does not work out.I plan on doing power steering.Do you know what year/model pump/box I need to get the parts from to put on my truck.I heard 1/2 ton dodge but dont know what year to look for,Thanks for the help,RR
