Solid Front End Conversion for Durango - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-21-2002, 12:13 AM
I have a 99' Dodge Durango that I want to switch to a Solid Front Axle.. what all do I need.. I have a 4in suspension lift with 33s right now.. I know I am going to need spring hangers and four inch springs.. what type for what car? Now what are my options for the solid front axle? Its a Driver's side drop so what are my options? Good idea or what?
<font color=red>[img]/wwwthreads_images/icons/cool.gif[/img] '78 CJ7 sold, 94 Cherokee 2WD 6[img]/wwwthreads_images/icons/cool.gif[/img]</font color=red>
post #2 of (permalink) Old 02-21-2002, 01:14 AM
Smokngun's Avatar
Re: Solid Front End Conversion for Durango
Sounds like a great idea to me! I would look into a late model Ram front setup. Axle, coil springs, 4 link bars and all. They should be a drivers drop as well (It's been a while since I sold my '95) The overall width may be a bit on the wide side, but I'd bet the height of stock 1/2 ton springs would be a close match to the 4" rear springs you have now. get out the tape measure and let us know!
Mike H.
1983 CJ-7 Laredo, 1991 Cherokee Ltd.
Smokngun is offline
post #3 of (permalink) Old 02-21-2002, 02:58 PM
What all would be involved?
post #4 of (permalink) Old 02-22-2002, 12:50 AM
Smokngun's Avatar
If the axle is the correct width (or a liveable dimention) and assuming you are using a Ram front end, you would have to...
Locate and weld on mounts for the four link bars to your frame. This would include moving the brackets on the axle if the width id wrong for the Durango frame.
The coil spring perches will have to be installed (somewhere) on the Durango frame as Durangos use torsion bars. You can determine ride height by where you mount the perches.
Steering: The Durango is Rack and Pinion, the Ram uses a standard gearbox and linkage to each steering knuckle. But both axles (Durango and Ram) are front steer, you would have to decide which system you are going to go with. I don't think the R&P would work that well with a longer travel suspention, but changing to gearbox would be a pain.
At this point shock mounts and brake lines are the little things, but they do have to be addressed. All of this sounds like a big pain for two more inches of tire. I'm not much of a fabricator and I've just hit on the 'hi' spots (I know I missed a ton). For more detailed info on a custom swap like this you might want to check out the Toyota board (they are always swapping solids where IFS used to be) or the Short Wheelbase Jeep board. You wont find a better group of fabricators than those guys! I'm thinkin' a body lift and cutout fender flares would be the ticket. Good luck with your decision.[img]/wwwthreads_images/icons/cool.gif[/img]
Mike H.
Smokngun is offline
