Changing dif fluid, as easy as it looks? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-31-2002, 01:39 AM
SHOTGUN
Is changing the differential oil as easy as it appears to be? A couple of months ago we had the axle end U-joints replaced my 2500, and our mechanic said the fluid that came out looked like it was due for a change. (I'm only scrapping up the money now, monthly payments are a %&#*^). Anyhow is it as simple as loosen bottom bolts to drain(or does it have a drain plug?), take cover off, put new gasket on, then add oil. Is it really that simple? Would it only take one bottle of gear lube?
post #2 of (permalink) Old 01-31-2002, 12:41 PM
Re: Changing dif fluid, as easy as it looks?
yup that easy / take cover off sillygoop it back together or buy gasket and put it back together / either way / the factory uses sillygoop / dana 60 you need at least four Qrts to fill it / good luck and MOPAR TO YA /////////WED
post #3 of (permalink) Old 02-02-2002, 12:23 AM
superswamper's Avatar
And if you have a limited slip gear then you need an 8 oz friction modifier additive per axle $6.00 each. Very easy but the hardest part at times is popping off the diff cover if its stuck real good.
superswamper is offline
