xr's a money pit - Page 2 - Off-Road Forums & Discussion Groups
Dirtbike Lounge Hang out and talk two wheels. For Tech and Racing specifically, see those forums below.
post #11 of (permalink) Old 09-05-2001, 04:03 PM
Re: xr\'s a money pit
i noticed too when i was showing my buddies some of the stuff i bought that there apears to be deep scratches on the insides of the inpection caps over the exhaust valves. does anybody know why this could of happened the one cap was only on the bike for one ride before she died
post #12 of (permalink) Old 09-05-2001, 04:08 PM
this is what it used to look like
post #13 of (permalink) Old 09-05-2001, 05:37 PM
USED TO are the key words in that sentence
When in doubt, GAS IT
post #14 of (permalink) Old 09-05-2001, 09:50 PM
I just had me 83' Xr200 engine rebuilt. The cam for it cost around 70$ and the bearing was another 25$. Had toorder the cam straight from Honda. Good luck
post #15 of (permalink) Old 09-06-2001, 11:13 AM
Ok yz quick, how old were you in 1985?
post #16 of (permalink) Old 09-06-2001, 12:41 PM
5 OR 6, DEPENDING ON THGE MONTH ,WHY?
post #17 of (permalink) Old 09-06-2001, 12:42 PM
SORYY, 6 OR 7
post #18 of (permalink) Old 09-06-2001, 01:41 PM
i was reading through my clymer book to see if i can start putting the thing together before i forget where stuff went. I came across a problem in the manual it says you have to take it to a dealer to get the counterbalancer aligned. is this true? so far the book has said like a dozen times to take it to the dealer for various things. they also said i had to take it to a dealer to get the crank out. A over sized socket and a few light taps from a hammer took care of that. I just don't want to press the crank in and have the balance off. the cheap bastards cant even tell ya what position to put the balancer. i would asume it would only fit one way or it would hit the crank weight. definitly dont want to tear up the crank!
post #19 of (permalink) Old 09-06-2001, 01:51 PM
See if you can take a boo at the Honda shop manual and check if the info is in there. Sometime they'll recomend the dealer perform a task but if you want to do it yourself they'll explain how.
post #20 of (permalink) Old 09-06-2001, 02:49 PM
WHEN PUTTING THE CRANK BEARINGS into the case, freeze the bearings and torch the case with propane thay will fall in. then let the bearings/case sit in the sun and put the crank assembly ine the freezer for about 6 hours or till real cold then put the crank into the case bearings. when you heat things they expand, freeze vice versa. thats why they say never work on a hot motor, everthing is expanded and tight, unlike your mother, sorry had to!
