high compressoin piston? - Off-Road Forums & Discussion Groups
Dirtbike Lounge Hang out and talk two wheels. For Tech and Racing specifically, see those forums below.
post #1 of (permalink) Old 07-24-2001, 06:00 PM
what are they? i see bikes and quads with them but cant figure out what they are.
post #2 of (permalink) Old 07-24-2001, 07:22 PM
portgrinder
Re: high compressoin piston?
a piston that is 'taller', so when it is at tdc it squeezes the air above it more. giving you more compression, and in theory more power
You wear your silver chain but the cross won't stop the lies,you believe in nothing
Kenton Thomas,Portal
post #3 of (permalink) Old 07-24-2001, 09:29 PM
It will give it a bit more power, IF your piston and rings are BAD, then you will notice a big change.
<font color=blue>UGH, I HATE WHEN THAT HAPPENS.</font color=blue>
post #4 of (permalink) Old 07-24-2001, 11:04 PM
ok
post #5 of (permalink) Old 07-25-2001, 08:39 AM
imagine you have a can of soup with the bottom cut off.put your fist in this can( this would be the piston and the can the cylinder) say the can is 10 inches long. you start your fist at the bottom and push up and compress the air in the can(cylinder) to 1 inch from the top of the can. so now you have takin 10 units of air and and compressed it to one unit. this would be a 10:1 compression ratio, do you follow.
welll take the same scenario but make the fist a little taller on top. you will still start from the same postion but the air will be compressed more due to less room between the fist(piston) and top of the can(cylinder head) creating a higher compression ratio. does this make anymore sense??
post #6 of (permalink) Old 07-25-2001, 02:34 PM
more ponies...i think he understands YZ...he should.
